Old 16-06-08, 03:15 PM   #1
startrek.steve
Default Just bought an SV650 - hints?
Just bought one of these beauties 02 SV650S.
Upon looking at the spark plugs, they look a bitch to remove, any hints guys?
Steve
Old 16-06-08, 03:20 PM   #2
hovis
Default Re: Just bought an SV650 - hints?
back one is easy.
front one you need to remove the bolt in the rad so it swings out of the way a bit
ps ello
Old 16-06-08, 03:23 PM   #3
fizzwheel
fizzwheel's Avatar
He's right you know, but also if you undo the fairing bolts and pop them off the mounting lugs it makes it easy to swing the rad forward.
The suzuki plug spanner that comes in the toolkit in my experience is the best way of getting the front plug out.
When you refit the HT lead make sure you put the grommet on properly and thats its recessed down into the head otherwise you'll run a greater risk of getting water in there when it rains.
HTH
Welcome to the forum.
Old 16-06-08, 03:37 PM   #4
sv650k4
yip as said back one easy and so is the front when you take the rad bolts out and swing it forward out of the way.
defo not as bad as what it looks.
Old 16-06-08, 06:45 PM   #5
Dangerous Dave
Welcome to the site, as said the back one is easy just pop the tank up. As for the front you'll need to remove your front side fairings and then undo the bottom bolt securing the rad and swing it forward, not much room but its enough!
Old 16-06-08, 06:49 PM   #6
startrek.steve
Cool Re: Just bought an SV650 - hints?
Thanks for the info guys, any other things I should know about? What's the mpg like, and tyre life?
Any weak points? (apart from my licence!)
Old 16-06-08, 06:55 PM   #7
Dangerous Dave
Originally Posted by startrek.steve View Post
Any weak points?
If you are planning on riding in the rain get yourself a fender extender to keep the water off the front spark plug!
Old 16-06-08, 06:58 PM   #8
DoubleD
Hello and welcome to the .org
as above really when changing the plugs, just put the HT rubber grommets back on the right way up, there should be a little arrow on the rubber grommet according to the Haynes manual
Old 16-06-08, 07:23 PM   #9
rowdy
rowdy's Avatar
Just make sure all the bolts that will be needed to be undone i.e. brake pad pins footpeg rear brake lever gear selector etc are well lubed as suzuki are shy of using it and these things can be a b**** to undo but as yours isn't new then these things should have been done already.
Old 16-06-08, 08:07 PM   #10
MR UKI (1)
Buy a pointy
I'm new to all this just bought an SV650 K6 Sport pupdog123 SV Talk, Tuning & Tweaking 21 01-09-07 10:47 AM
I've finally bought an SV650..... Nearly. Xerbraski Bikes - Talk & Issues 17 08-06-06 10:49 AM
Just bought a new 2006 SV650 ohiobiker SV Talk, Tuning & Tweaking 2 24-04-06 12:11 PM
Bought Used SV650 with 180/55 ?? rcmark Tyres 2 07-08-05 09:17 PM
Just bought a '99 SV650 murphydome SV Talk, Tuning & Tweaking 14 03-06-05 07:36 PM
