Old 12-07-08, 07:10 PM   #1
startrek.steve
Default Footrest bracket slightly loose - problem?
Going over the bike today, & I noticed the bracket the right footrest fastens to, rotates a few degrees slightly, the brake pedal shaft goes through the centre of it, and I cant find a bolt to tighten it up. Is this a problem? or usual? K2 o2 Curvy.
Steve
Old 12-07-08, 07:15 PM   #2
21QUEST
21QUEST's Avatar
Default Re: Footrest bracket slightly loose - problem?
Steve
Err are you sure? Yeah, it shouldn't rotate at all. It's got two bolts holding it to the frame.
Ben
Nemo me impune lacessit.
Old 12-07-08, 07:18 PM   #3
Nah I think he means the fork thing that the footrest is attatched to the shaft with the C clip.
The bolt for that is 8mm allen bolt which you have to take the footrest hangar off the bike to get to, it's behind the footpeg mount.
Old 12-07-08, 08:13 PM   #4
21QUEST
21QUEST's Avatar
Seeee......AFAICR you have a problem if the forked thingy has movement in the same axis as the bolt goes in.
I've never come across a problem of the bolt being loose myself but possible but fairly sure you shouldn't be able to rotate it.
Ben
Old 12-07-08, 08:16 PM   #5
If it's not tight it will rotate just a little bit not all the way
Old 13-07-08, 10:54 AM   #6
Dangerous Dave
+ 1
Slightly freaked out now. Ace-T Idle Banter 3 03-06-08 11:34 PM
Footrest bracket / spares good source? mbuk SV Talk, Tuning & Tweaking 2 14-02-08 05:50 PM
Passenger footrest bracket jimstuart1001 Stuff Wanted 0 24-09-06 07:11 AM
Slightly OT - replacement R6 key mburnstead Bikes - Talk & Issues 5 22-05-06 05:29 PM
radiator lower mounting bolt - slightly loose? madEG SV Talk, Tuning & Tweaking 5 05-04-05 04:07 PM
