Old 02-11-08, 10:47 AM   #1
Baz
Default Whats in a rear hugger fitting kit?
Hi All
I have just found a rear hugger that would fit my bike for an absolute steal. Only thing is it doesn't have a fitting kit with it.
What exactly is in the fitting kit? Is it essential or is just a selection of bolts that I could "borrow", from my work?
If it is needed how much would one of these go for?
Any advice greatly appreciated.
Old 02-11-08, 10:50 AM   #2
petevtwin650
Default Re: Whats in a rear hugger fitting kit?
What bike are we talking about and which Hugger?
Most Huggers, but not all, use the existing bolts I believe.
Old 02-11-08, 10:50 AM   #3
Dangerous Dave
For an SV three bolts (two chain guard and one rear brake hose clamp) and possibly some rubber grommets.
Which make is the hugger?
Old 02-11-08, 10:54 AM   #4
Baz
For a 99 SV650S. The hugger is apparently Suzuki but it's on e-bay so not 100% about that.
Old 02-11-08, 10:56 AM   #5
Dangerous Dave
Comes with three bolts, you should be able to reuse your chain guard bolts but you may need a slightly longer bolt for the rear hose clamp.
Old 02-11-08, 11:00 AM   #6
Dangerous Dave
If you PM me the link I will confirm if it is OEM, don't worry i am not interested in buying a hugger.
Old 02-11-08, 11:01 AM   #7
schofs
Just fitted my hugger (although it's a Red Fox on an 08 Bike - but the fittings are likely to be very similar).
It came with two bolts which replaced the existing chain guard ones... but I see no reason why I couldn't have used the original ones. The brake line guide bold was re-used in holding the hugger on.
Old 02-11-08, 11:07 AM   #8
Baz
Cheers for that DD but I just bought it anyway.
Keep fingers crossed it'll be ok.
Thank's for the help guys.
Help fitting rear hugger lancasterlad SV Talk, Tuning & Tweaking 10 09-08-07 06:17 PM
black rear hugger or carbon rear hugger? chipnix SV Talk, Tuning & Tweaking 9 05-07-07 04:05 PM
Fitting a rear hugger advice needed! krhall Bikes - Talk & Issues 21 20-05-07 10:18 AM
Whats involved in fitting a fender eliminater GC-SV Bodywork 15 29-06-06 06:26 AM
Whats the deal with fitting a new can dytron SV Talk, Tuning & Tweaking 5 11-05-06 04:14 PM
