Old 18-05-07, 05:00 PM   #1
krhall
Default Fitting a rear hugger advice needed!
Any ideas what I need and how to do it?
Does it use the existing fittings from the chain guard etc?
it is second-hand and in great condition just fitting it now hopefully.
Kev
Old 18-05-07, 05:26 PM   #2
Rich
Rich's Avatar
Default Re: Fitting a rear hugger advice needed!
Remove the old chain guard using a screwdriver (crosshead).
Remove the crap flap as i've heard it called under the tool box using an 8mm socket i think, maybe 10mm , one of the two.
Remove the allenkey screw holding the brakeline bracket on, keep screw will need to put back in when the huggers in place. (if it's not oem, the bracket might not fit and then you can cut it off or bend it to fit)
Roll hugger over the wheel into place, replace the crosshead screws that were holding the chainguard on with the allenkey screws that should have been supplied. If not just use the crossheads, makes no difference. Don't tighten them all up yet though!!
Bolt the hugger in place loosely under the tool box!
Replace the allenkey screw for the brakeline, check theres an equal gap both sides of the tyre, and when happy tighten up and jobs done.
HTH Rich!!
RIP Hovis - Unlucky Boyo
Old 18-05-07, 05:31 PM   #3
krhall
One of the side crossheads has rounded off!!!!
Any ideas?
Old 18-05-07, 05:35 PM   #4
hovis
impact driver might di it?
Old 18-05-07, 05:37 PM   #5
krhall
a what?
Old 18-05-07, 05:39 PM   #6
Rich
Rich's Avatar
Drill it out with a small metal drill bit, 3 or 4mm maybe. Or get a srew removal drill piece and use you drill in reverse to get it out. Orrrr it your really careful, use a hacksaw and cut a deep enough cut for a flat head screw driver to undo it, i've done that at work many a time, use some wd40 to loosen it up though!!
Old 18-05-07, 05:39 PM   #7
muffles
Impact driver is just a socket with only 6 sides (the black ones). They grip better than the 12-side normal sockets. I wouldn't have thought the bolts would be that tight, you could try a set of molegrips?
Old 18-05-07, 05:39 PM   #8
hovis
http://en.wikipedia.org/wiki/Impact_driver
Old 18-05-07, 05:40 PM   #9
hovis
eh? no its not
Old 18-05-07, 05:41 PM   #10
muffles
Hmm, oh yeah they're screws not bolts. Hovis' impact driver comment got me! I'd try cutting anotherline with a hacksaw, or perhaps if it's not too rounded off try a bigger crosspoint screwdriver, unless it is already as big as will fit?
Whats in a rear hugger fitting kit? Baz SV Talk, Tuning & Tweaking 7 02-11-08 11:07 AM
Hugger, Belly Pan, Tail Tidy. Advice needed nomad SV Talk, Tuning & Tweaking 16 27-09-07 01:57 PM
Help fitting rear hugger lancasterlad SV Talk, Tuning & Tweaking 10 09-08-07 06:17 PM
RACE CAN FITTING - ADVICE NEEDED viner SV Talk, Tuning & Tweaking 3 24-06-05 07:03 PM
Urgent advice needed fitting undertray to K1 SV650S steve mac SV Talk, Tuning & Tweaking 5 20-01-05 02:16 PM
