Old 27-11-08, 06:48 PM   #1
glang
Default draining fork oil
Its a really old topic I know but what happens if u take the bolts out of the bottom of the forks? Is it too much to hope that fork oil will drain out - obviously with the front wheel off the ground and will it go back together afterwards?
Old 27-11-08, 06:55 PM   #2
Biker Biggles
Biker Biggles's Avatar
Default Re: draining fork oil
No you need to take them out and tip them upside down.
Old 27-11-08, 07:03 PM   #3
Mr Speirs
Mr Speirs's Avatar
I believe those bolts hold the damping rods. If you undo them they will become loose. They are quite tricky to put back together when they're apart let alone built up.
Even if it were possible you would have to take the wheel out to get to the bottom damping rod bolt. So you would only be a few bolts shy of having the forks out anyways.
Old 27-11-08, 07:13 PM   #4
Don't bother removing the damper rod bolt.
Old 27-11-08, 07:15 PM   #5
Alpinestarhero
Can you not use a big ol' pump? I was planning on sucking out thefork oil from my forks and then putting in springs and new oil
if i change the sprrings, do I have to change the oil though? Can i just fish the springs out and pop in the new ones?
Old 27-11-08, 07:17 PM   #6
People who haven't got time to do a job right always seem to manage to find time to do it twice.
Old 28-11-08, 10:00 AM   #7
glang
alright I get the message I'll take em out its just that I like to investigate all possibilities and if I don't like the change I might be doing the job a few times!
Old 28-11-08, 10:06 AM   #8
Ceri JC
Replacing fork oil is one of those jobs that is very slow the first time, but very quick to do once you've gotten your head round it. If at all possible, get someone local who has done it before to show you/help give you a hand.
Old 28-11-08, 10:13 AM   #9
skeetly
skeetly's Avatar
Thats profound and consider it stolen.
/makes off with someone elses proverbial
skeetly is offline   Reply With Quote
Old 28-11-08, 10:17 AM   #10
petevtwin650
ASH, I often wondered about a pump too.
However, especially if the oil is old, I would imagine there would be some oil left so best to tip em up and maybe flush them out too.
Oil is under 20 quid, are you really that hard up? , plus the springs may displace a different amount of oil so you'll have to redo the air gap anyway.
Draining Coolant lazymanc SV Talk, Tuning & Tweaking 5 12-05-09 12:09 PM
alarm draining out battery abdul.aziz SV Talk, Tuning & Tweaking 2 10-05-09 12:56 PM
Constant Draining Battery decca1o Bikes - Talk & Issues 3 13-03-09 10:22 AM
Battery draining - Help PaulyMac SV Talk, Tuning & Tweaking 19 01-06-07 09:30 AM
Tip for draining fuel tank Yarodia SV Talk, Tuning & Tweaking 8 11-11-05 11:19 PM
