I need to drain the coolant before I do my engine swap, but the Haynes doesn't seem to say how - it refers you to chapter 1 of the coolant section but that just warns about not opening the rad cap when the engine is hot.
So, where do you drain the coolant from, and how do you avoid it splashing all over your engine casing and peeling off the paint? |
AFAIK there should be a bleed screw thing you take out and it should drain out.. failing that you could just take the hose out of the radiator and run the engine for a short while. Won't do it any harm.
Little 10mm headed bolt at the bottom of the water pump
Curvy With Lots Of Bits ...
But Still More To Come ![]() |
Cheers, now to find some kind of plastic funnel to catch the stuff.
I like the colour of your coolant :P
Looks like slime |
alarm draining out battery | abdul.aziz | SV Talk, Tuning & Tweaking | 2 | 10-05-09 12:56 PM |
Constant Draining Battery | decca1o | Bikes - Talk & Issues | 3 | 13-03-09 10:22 AM |
draining fork oil | glang | SV Talk, Tuning & Tweaking | 21 | 10-12-08 04:57 PM |
Battery draining - Help | PaulyMac | SV Talk, Tuning & Tweaking | 19 | 01-06-07 09:30 AM |
Tip for draining fuel tank | Yarodia | SV Talk, Tuning & Tweaking | 8 | 11-11-05 11:19 PM |
