Old 06-02-09, 02:43 PM   #1
DaveP
Default Glue for fender extender?
For my fender extender....? As i have no intention of screwing anything
Thank you.
Dave
Old 06-02-09, 02:50 PM   #2
husky03
Default Re: which glue??
Araldite
Old 06-02-09, 03:29 PM   #3
embee
embee's Avatar
Yep, an epoxy resin like Araldite. Note that the fast setting versions aren't quite as strong as the slower (24hr) ones, so if you have the time go for a "standard" type. Check temperature range for use, it'll be slow in the cold, indoors is preferable this time of year.
As with any bonding, make sure the surfaces are totally clean and dry, best way is roughen with coarse abrasive paper. You'll probably find the guard and extender don't match absolutely perfectly, so use clamps. Someone lent me some spring clamps, like huge clothes pegs, which are perfect.
Old 06-02-09, 03:48 PM   #4
fizzwheel
fizzwheel's Avatar
I used a product called "Evostick Wet Grab" they sell it in B & Q, worked a treat and I've stuck two fenda extendas with it now and neither have moved or fallen off.
As Embee says, make sure you roughen up both the extenda and the mudguard as this give a better key for the glue to set.
I've seen other people recommend a product called "Sikaflex" as well, but I've not got any experience of that myself.
Old 07-02-09, 10:19 AM   #5
Miles
I also used the stuff from B&Q after reading it on here. About £6 and works a treat.
Old 07-02-09, 01:50 PM   #6
Mr Speirs
Mr Speirs's Avatar
Default Re: Glue for fender extender?
Silicone Sealant is what I used. Still holding on strong.
Old 07-02-09, 02:16 PM   #7
shonadoll
I used the marine sikoflex, salt resistant too.
Old 07-02-09, 02:17 PM   #8
Tim in Belgium
Araldite worked fine for me, roughly 15k miles and plenty of track days.
Old 07-02-09, 02:49 PM   #9
Thingus
I was thinking the same thing. Halfords open until 6pm tonight, yes please.
Old 07-02-09, 04:26 PM   #10
missyburd
Celibacy's a terrible thing
Sorry couldn't resist, am leaving now
Oh and duck tape is what you need
Fender extender glue Miles SV Talk, Tuning & Tweaking 14 23-11-08 06:01 PM
mud guard extender / fender extender to fit K4 650s Chuky Stuff Wanted 5 26-10-08 11:58 PM
Any recommendations for glue for Fender Extender? Topaz SV Talk, Tuning & Tweaking 9 05-05-06 01:22 PM
Fender Extender leegriffiths128 SV Talk, Tuning & Tweaking 4 07-03-06 07:35 PM
Fender Extender Londonoz SV Talk, Tuning & Tweaking 17 20-02-05 07:29 PM
