Old 02-06-09, 02:11 PM   #1
breakz187
Default Steering feel after chain replacement
Does anyone here ever notice that motorcycles hand differently after a chain replacement? My chain was a mess and adjusted out pretty far, not much adjustment left.
Now that i have a new chain and sprocket installed it feels like it turns alot easier. Is this normal, or even related?
Even if i go in a straight line and just wobble the steering from left to right, it moves more freely.
I had to replace the front wheel bearings a month or so ago, so i'll be jacking it up to ensure these haven't lunched themselves again. They failed really badly last time - totally destroyed.
Old 02-06-09, 02:15 PM   #2
breakz187
Default Re: Steering feel after chain replacement
Reason i ask is that i think this may be responsible by changing the wheel base of the bike.
Old 02-06-09, 02:16 PM   #3
RatchetJob
My first thoughts are that your rear wheel alignment was out and when the new chain was fitted the alignment was then set correctly.
If the wheel alignment was bad enough it would affect cornering. Did you notice if it was easier to turn one way or the other?
Old 02-06-09, 02:16 PM   #4
ophic
ophic's Avatar
yes i've noticed that the feel changes - not surprising as the geometry of the bike becomes slightly different. Must be slightly easier to wheelie too
Silver SV650SK3, Fuel exhaust
Old 02-06-09, 02:29 PM   #5
breakz187
The alignment was spot on using the method where you measure the length of the bolt that the adjuster nut sits on.
Will double check the wheel bearings again.
I rather like the feel of it to be honest, just having a little trouble building confidence back up with the bike to 100%, since the engine blew up on me.
Replacement chain adjusters lazymanc SV Talk, Tuning & Tweaking 0 08-04-09 12:03 PM
Cam chain replacement - is that normal? Knaapie SV Talk, Tuning & Tweaking 19 09-11-08 10:27 PM
Chain & Sprocket replacement inspectorgadget SV Talk, Tuning & Tweaking 54 27-11-07 12:31 PM
Replacement Chain and Sprockets sharriso74 Idle Banter 7 22-05-06 11:51 AM
Replacement Steering Stem Head bobit69 SV Talk, Tuning & Tweaking 3 29-05-05 11:47 AM
