My bike's battery got cooked for the second time last weekend. Never blew any fuses, only the headlight and the bike sputtered to a stop.
I replaced the battery and installed a '08 cbr600rr upgrade regulator. Now it will crank, but it will not fire. I get volts at the coils, r/r, main fuse, battery, o/w wire going into the CDI. Does anyone know what it could be? I don't know how to test the CDI coming out and I'm afraid it may have gotten fried when I was over-charging... But I thought it may also be the signal generator and I don't know how to test that either. Any help would be very much appreciated. It's too nice out to be stuck in the garage! |
Have you checked that there is a spark at the spark plug? Is it cranking strong enough?
Yes. I pulled out the rear plug and grounded it while cranking. I got no spark. Do you think over-charging could ruin the coils? I am getting volts on the clips at the rear of each coil.
The Sick Man
have you got access to spare ignition unit from another curvey (gen1)
OTR: KTM 690 Duke R 2015 Full Akro SIDELINE: Kwak ZX636 A1P 2002, Red, R&G's, Yoshi, Double Bubble Screen GONE: Kwak ZX-7R P1, Full Akro, Undertray, Screen GONE: SV650S K2 Very Bruised & Without Fairing, Motovation Frame Sliders, R&G Ally Sprocket Toe Protector, HEL 2 Line Setup, GSXR K1 600 RWU Forks, Barnett Clutch & Springs, Penske 8981 Shock, Gilles Ti Rearsets, Steel Barends, Scottoiler, AFAM Chain & Sprockets, Twin FIAMM Horns, Skidmarx Bellypan, Full Micron Zeta Steel System, Cut down undertay. Forum Problems & Information / Site Suggestions |
Also, yes there is lots of cranking power.
Try new coils, wouldn't they be cheaper?
Got a working CDI on eBay. Plugged it in and it fired right up. So, all things considered... Replace your r/r if your curvy has 15k+ so you don't have to go through what I went through. This is a common problem and needs to be monitored. The faulty r/r fried my CDI, tach, headlight bulb, tail bulbs, and 2 batteries when I went on a long ride. Check your voltage and make sure it's safe like <15v or so. My r/r upgrade was a '08 CBR600rr model that had a slotted bolt hole and mounted right up with no issues. Wiring is easy, and remember to put a 30a inline fuse if you go direct to the battery.
Hope that this helps someone else in the future. |
Optimate battery charger drains the battery | flymo | Bikes - Talk & Issues | 10 | 10-06-09 10:41 AM |
MOT failure | dirtydog | Bikes - Talk & Issues | 26 | 26-04-09 12:16 PM |
MOT failure | pinman | Bikes - Talk & Issues | 46 | 22-04-09 09:27 PM |
What a con! – MOT failure | Blue_SV650S | Idle Banter | 30 | 25-05-07 07:11 PM |
Battery/Starting problem - new battery hasnt fixed it! | Aaron | SV Talk, Tuning & Tweaking | 13 | 24-01-05 05:21 PM |
