Old 15-06-09, 01:32 PM   #1
Neeja
Default Brakes question
Right-o, last weekend fitted new pads, cleaned up pistons etc., and this weekend changed the brake-fluid as the stuff that was in there was manky and the brake-lever was stupidly spongy.
After bleeding from just about everywhere possible (including raising calipers and tapping bits and bobs to get air-bubbles to rise), and doing the cable-tied-overnight trick, the brake lever's still spongy. The bike will stop just fine, and I can lock the front wheel at 10mph with only using half the lever travel, but the lever comes all the way back to the bar if you pull it back fairly hard. The adjuster's set on number 1, btw, on number 5 it gets to the bar before the brakes are fully on.
I've ordered some braided lines as I'm pretty sure that these are knackered (nearly 27k on 8 year old stock rubber hoses), but my dad's also suggested that the master cylinder may be allowing fluid to flow back through it.
Any other suggestions?
Old 15-06-09, 01:38 PM   #2
thedonal
Default Re: Brakes question
I found the front brakes quite spongy still after fitting braided lines and overhauling the calipers. I think it's an SV thing. My rear brake has always been very spongy.
Master cylinders, perhaps?
Old 15-06-09, 03:20 PM   #3
flymo
flymo's Avatar
Its possible that the m/c seals are in need of replacement. Sounds likely that you still have some air hanging around in there. Make sure there isnt any at the top of the brake lines where the banjo joins the master cylinder. You can open up the banjo slightly to bleed but I prefer to just make sure there is an uphill path right the way to the reservoir by leaning the bike to its left on the sidestand and turning the bars fully to the right.
Feel free to pop over to my place if you want a second pair of eyes on it.
Old 15-06-09, 03:20 PM   #4
Neeja
Only thing I have to say about this is that my housemate's brakes are fantastic - on the number 1 setting on the adjuster it only comes back about an inch and won't go any further than that at all, so it can't be 100% SV specific
Old 16-06-09, 08:57 AM   #5
johnnyrod
johnnyrod's Avatar
I'm with Flymo, when my master cylinder seals had gone it felt a lot like you couldn't bleed all the air out.
Quick question about SV brakes Dave20046 SV Talk, Tuning & Tweaking 25 19-03-09 06:58 PM
Me Brakes are Done in! I'm_a_Newbie SV Talk, Tuning & Tweaking 7 16-02-09 04:59 PM
Quick simple techy question about brakes monkey Bikes - Talk & Issues 5 23-01-09 03:50 PM
Better brakes rob13 SV Talk, Tuning & Tweaking 12 21-09-07 04:17 PM
Numpty question again....brakes cuffy SV Talk, Tuning & Tweaking 7 27-02-06 04:58 PM
