Old 25-08-09, 08:05 AM   #1
Lucas
Default regulator/rectifier
One quick tech question:
With engine at idle, is it normal for the regulator/rectifier's negative wire (the black with white stripe) to get warm to the touch?
(is it because it carries a high current to charge the battery?)
or could it be casued by dodgy reg rec to battery wiring?
Thanks
Old 27-08-09, 07:17 PM   #2
warrenhewitt10
Default Re: regulator/rectifier
i dont think the wires are supposed to heat up on anything, im sure mine dont, as far as i know it should only be outputting about 14-15 volts into the battery
Old 27-08-09, 07:30 PM   #3
Lucas
i wonder if heating is caused by oxidised because there is a higher resistance?
Old 27-08-09, 08:44 PM   #4
Spiderman
Where the hell am I?
Spiderman's Avatar
that sounds like a possibility to me mate, the higer resistance would cause some heat.
I'd send Squid a quick PM about that, he'd know for sure
Old 28-08-09, 11:27 AM   #5
Cazza
The R/R itself will get hot, that's normal, and the bit of wire near the unit itself will warm up a bit because it's connected to something hot.
If the connector block is getting noticeably hot though then it's because the connectors aren't making good contact and probably the spades are a bit slack and possibly dirty too.
Old 28-08-09, 04:51 PM   #6
TSM
The Sick Man
TSM's Avatar
Arcing you mean? like on many bikes ends up to a melted connector block
Old 28-08-09, 05:39 PM   #7
Depends how hot. To be sure, check the voltage across the wire in question. Serious resistance under load (i.e headlights and engine on) will manifest itself as a voltage drop.
Regulator Rectifier GeneticBubble SV Talk, Tuning & Tweaking 4 25-04-09 01:42 PM
I need a Rectifier / Regulator. Marv Stuff Wanted 3 19-08-08 12:43 PM
Regulator-rectifier beaniebikerbabe SV Talk, Tuning & Tweaking 15 27-05-08 12:33 PM
K2 regulator/rectifier, new in box northwind For Sale - SV's and SV related items 0 22-02-07 09:14 PM
Regulator/Rectifier Steve T SV Talk, Tuning & Tweaking 3 10-10-04 10:34 PM
