Old 04-09-09, 06:28 AM   #1
Geoffrey
Default HID bolt-on conversion
hello all, i know this has been covered a few time before but i am looking for your opinions on the best bolt-on hid conversion for both a pointy and curvy sv.
please note i am not technically minded, i am looking for a simple bolt-on kit which requires not soldering etc.
any comments would be appreciated.
thank you in advance
Geoff
Old 04-09-09, 07:34 AM   #2
Brettus
Default Re: HID bolt-on conversion
I think a lot of members (myself included) will recommend hids4u.co.uk their kit was spot on for me. running twin 55w ones was too much for the stock fuse so I had to wire a new run for them that was all. but thats only because I'd got two of the higher kits.
Old 04-09-09, 07:54 AM   #3
Geoffrey
so that is only with the higher spec kit, which would you recommend and which would require no modifications
Old 04-09-09, 09:03 AM   #4
Hey Geoffrey, sorry I did not get back to you earlier, busy days!
Mine is the 35w hids4u kit, I have not fitted enough of them to say any particular make is better than another though.
With any there will be some small wiring mods to make.
Old 04-09-09, 09:05 AM   #5
the_lone_wolf
Captain Awesome
the_lone_wolf's Avatar
The kits predominantly come from the same factories in china anyway, they all look the same, the reason I go to HIDs4u is because they've always been good sellers and their customer support is excellent...
Wiring in 2x 35W HIDs will require a relay most likely, if you're not confident doing it get someone who is and don't just fudge it. It's honestly not difficult though, take your time and do it right
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 04-09-09, 09:09 AM   #6
Worst that can happen is it all catches fire anyway
Old 04-09-09, 09:18 AM   #7
ophic
ophic's Avatar
stash a mini fire extinguisher under the seat, be reet.
Silver SV650SK3, Fuel exhaust
Old 04-09-09, 10:19 AM   #8
Geoffrey
was it straight connect up to the battery type fitment?
how easy is this to do? also could somebody explain it a little more in "idiot terms" the exact process please?
thanks for that...
Old 04-09-09, 11:21 AM   #9
Yes most of them which use a relay come with a H4 male plug which you plug directly in instead of a bulb, then connect the feed wires directly to the battery. It is all fused and switched itself, so the actual headlight switch on the bars only controls a switching current for the relay.
Old 04-09-09, 11:51 AM   #10
madnlooney
just ride abit faster and the flames will die out
Fairing bolt / Mirror bolt MiniMac Stuff Wanted 0 02-07-08 10:26 AM
how to get the sump plug/bolt or filter bolt out without murdering someone? Paul the 6th Bikes - Talk & Issues 11 31-05-08 10:49 AM
m4a - mp3 conversion embee Idle Banter 17 04-06-07 09:22 AM
Help me build a spare bolt box; what are all the common bolt F16Falcon SV Talk, Tuning & Tweaking 10 07-05-07 08:42 AM
Seat Bolt and bar end bolt Colby Stuff Wanted 3 04-04-07 04:56 PM
