Old 03-10-09, 12:39 PM   #1
bantam
Default Small oil leak, 1999 SV650S
Hi all,
I have a small (doesent seem to be making much difference to the level, doesent activate the oil light) oil leak on my '99 SV650S. The leak seems to be coming from a pin hole in a hose above the crankcase next to the front cylinder. I havent had this bike long, so I cant say what the hose is... Any suggestions? Advice on a quick fix like a little hose clamp or something like that would be appreciated.
Old 03-10-09, 12:45 PM   #2
Default Re: Small oil leak, 1999 SV650S
Sounds like the breather pipe. Is it on left side?
Old 04-10-09, 06:45 PM   #3
bantam
Closer inspection with a Haynes book shows that its the hose that ends in the idle speed adjuster...
Old 05-10-09, 01:43 PM   #4
That's not connected to anything that contains oil, it's just a wire inside to turn a screw. Either it is oil used to lube this dripping out, or it is spraying mist elsewhere.
Old 06-10-09, 11:05 AM   #5
bantam
Yeah, thats what I thought, perhaps the oil is running down the pipe from somewhere else and dripping off where it appears to be leaking. Judging from the consistency and colour I think it is probably engine oil of some kind.
Fuel leak 1999 SV 400 SV400Rob Bikes - Talk & Issues 1 26-05-09 08:03 PM
1999 sv650s plowsie For Sale - SV's and SV related items 9 28-04-09 10:10 AM
SV650s sprung an oil leak SUPERSTARDJ01 Bikes - Talk & Issues 21 25-04-09 10:22 PM
Small oil leak infront or above the front sprocket? sv650k4 SV Talk, Tuning & Tweaking 6 09-09-08 09:17 PM
For sale, Red SV650s, 1999 Smiler For Sale - SV's and SV related items 1 07-03-06 12:25 PM
