Old 05-10-09, 10:46 AM   #1
aeroshaw
Default Instrument LED's
Dose anyone know what voltage the small led's are on the instrument panel?
Iv been looking on the usual websites, RS, Farnell ect.... and I Have found the LED's however there all rated between 3-5 Volts.
Just wondering if anyone Knows if they are 5v or 12V, I don’t want to risk popping something if the Instrument panel is £150.
Old 05-10-09, 11:10 AM   #2
ophic
ophic's Avatar
Default Re: Instrument LED's
It's highly unlikely they're 12V LEDs - they won't be wired directly to a 12V source. There should be some resistors in the circuit path to set the voltage to the required level.
And anyway, if you put an LED in with too low a rating, all you'd do is pop the LED itself. Nothing else should be affected. The tricky bit is the soldering.
Look here under "Instrument Bling": http://www.chewys-stuff.co.uk/ if you want a kit with instructions.
Silver SV650SK3, Fuel exhaust
Old 07-10-09, 01:41 PM   #3
joshmac
Send Adam (Dirtydog) a PM. He sent me a link a while ago to a site that does straight swap LEDs but I can't remember off the top of my head what it was.
Old 07-10-09, 02:06 PM   #4
dirtydog
Knob faced knobster
dirtydog's Avatar
The OP has a pointy, so he will need the kit from chewys
2011 Speed Triple 1050
Old 07-10-09, 02:08 PM   #5
joshmac
Ah OK, my mistake. Must've missed that
Old 07-10-09, 03:23 PM   #6
aeroshaw
Cheers Guys, I’ve sorted it now.
I got some Surface mount LED's from RS Components. They are ratted at 3.5v. They come in packs of 10 and are 30 Pence each!
They are a total pig to get off, I could have done with three pairs of hands, but re-fitting them was easy It took about 15 mins to do all eight.
Just tried it today and it looks blue
Old 07-10-09, 03:27 PM   #7
ophic
ophic's Avatar
could you supply a link or part number?
Old 08-10-09, 08:17 AM   #8
aeroshaw
This if for the Blue LED's
the link is:
http://uk.rs-online.com/web/search/s...duct&R=6545127
If it dosn't work the part number is: 654-5127
Old 08-10-09, 09:22 AM   #9
ophic
ophic's Avatar
Thanks mate. It's something i've been considering for a while - I might do it at some point in the future. Getting the right parts is half the battle.
instrument panel bulbs mikelcfc SV Talk, Tuning & Tweaking 7 28-10-09 05:26 PM
Instrument bulbs ranathari SV Talk, Tuning & Tweaking 6 07-07-09 10:47 PM
changing LED's in rev & clock..?? younggunns Bikes - Talk & Issues 2 01-04-08 12:12 PM
instrument bulbs Shinsei Jutsu SV Talk, Tuning & Tweaking 3 11-01-06 06:23 PM
LED's suzsv650 SV Talk, Tuning & Tweaking 33 20-06-05 08:26 AM
