Old 10-11-09, 06:35 PM   #1
steveg
steveg's Avatar
Default wire wool or wet and dry brakes
Hi All
Need to change rear brake pads , took a look at pistons tonight and there is quite a lot of surface corrison.
Sprayed some brake fluid while brake is in situ and used tooth brush , will need something more heavy duty
Is wire wool to heavy duty or would wet & dry 1000 be better ?
Cheers Steve
ex - red sv650s 06 reg
Now Triumph sprint 1050 ABS 05 Reg
AKA Papa Smurf
steveg is offline   Reply With Quote
Old 10-11-09, 06:37 PM   #2
Default Re: wire wool or wet and dry brakes
Not wire wool
Old 10-11-09, 07:58 PM   #3
Alpinestarhero
Autosol and some elbow grease?
Old 10-11-09, 08:18 PM   #4
steveg
steveg's Avatar
Thanks for the replies
As I am very heavy handed gonna go for 1500 wet/dry then autosol , think wire wool might be a bit dangerous ...
Cheers Steveg
AKA Papa Smurf
Old 10-11-09, 08:37 PM   #5
TightRS
TightRS's Avatar
I've used a green scourer with good success.
SV650S K5
GSX-R Shock, R6 Throttle, Oxford Hot Grips, R&G Crash Guards, Hugger, Fender Extender, Radiator Cover, Mirror Extenders, Stebel Magnum Horn, DL Handguards, Philips X-treme +80%, Denso Iridium Plugs.
TightRS is offline   Reply With Quote
Old 10-11-09, 08:42 PM   #6
Biker Biggles
Biker Biggles's Avatar
Is it corrosion or seriously hard crud?If its crud Id go for brake cleaner and elbow grease,but if it is corrosion Id think about overhauling the calipers with new pistons.
Old 10-11-09, 09:01 PM   #7
xXBADGERXx
I use Scotch Brite and a Brass bristled Spark Plug brush or suede brush .
Old 10-11-09, 09:25 PM   #8
Spiderman
Where the hell am I?
Spiderman's Avatar
tesco value cream cleaner on green scourer is almost as good as autosol. A wise man showed me this neat and dirt cheap trick.
The Wire Razor Idle Banter 5 25-07-08 06:32 PM
Unidentified wire yorkie_chris SV Talk, Tuning & Tweaking 6 15-09-07 08:46 PM
wire mesh bikerskez SV Talk, Tuning & Tweaking 3 04-02-07 11:45 AM
Which cables to wire accessories to ? oldjack SV Talk, Tuning & Tweaking 4 02-09-06 08:20 AM
Wire up switch? Bikerz SV Talk, Tuning & Tweaking 14 25-06-05 07:43 AM
