Old 24-11-09, 12:23 PM   #1
SUPERSTARDJ01
Default Boots?
Hi,
When buying motorbike boots do you have to buy a size or half larger than in shoes/trainers etc?
Thanks
Old 24-11-09, 12:30 PM   #2
Scoobs
Default Re: Boots?
Nope. Just get some that fit. There are differences between brands.
Old 24-11-09, 12:33 PM   #3
Swin
Swin's Avatar
Default Re: Boots?
In my Sidi's I had to go a size larger as they felt tight in my normal size. It seemed to be the width fitting more than anything else.
My winter boots - Frank Thomas Aquaboots - fitted perfectly in my normal size, but they are more of a leather-look wellie and are wider in any case.
Swin is offline   Reply With Quote
Old 24-11-09, 12:35 PM   #4
Sally
Default Re: Boots?
My Sidi's are a size larger than normal, but you should really try the boots on before buying, each brand varies, as luike football boots.
Old 24-11-09, 01:11 PM   #5
SUPERSTARDJ01
Default Re: Boots?
I have some frank thomas and I cant do up my boots with my leathers tucked in to them.
Old 24-11-09, 01:26 PM   #6
Holdup
Default Re: Boots?
I had the same problem with my jeans when i got a pair of boots, and my boots ended up being quite big in the foot, but my new TCX competizone s boots are 1 size to big in the foot (i have wide feet) but the only way to find out if they fit with your leathers is try them on with your leathers, dont forget leather gives, i found that i had to pull my leaters up a bit to zip up my boots but eventually they gave and i didnt have to pull them up
Old 24-11-09, 01:40 PM   #7
Warthog
Default Re: Boots?
My Alpinestars a a little bigger than I usually take for normal shoes. Nothing beats trying them on though.
Recomend some boots (not race boots) Baz Boots 20 19-06-09 10:43 PM
Boots vannus Riding Gear 18 13-03-09 04:39 PM
New Boots. Brettus Boots 7 21-02-09 08:22 PM
Which boots? cornishrider Bikes - Talk & Issues 28 08-10-07 06:22 AM
Boots localhost Bikes - Talk & Issues 19 27-08-05 11:57 AM
