I have a datatool gear indicator fitted to my sv650sk4. When i put it into gear it reads either 1 or 2 When in first gear. In neutral it always reads 0. When i'm driving the bike the leds just spin round and round. How do i set it?
hey don't know much about the data tool version but i can recomend healtech, works a charm
Hope you get it set up OK Nick. I had one fitted when I bought by SV and it is handy to have.
Garry ![]() |
Thanks to rictus01. I will check out the datatool website to reset it. Cheers for the replies.
Why is there a need for a gear indicator really? I usually know what gear i'm in when cruising by my speed! i.e 3krpm-40mph i'm in 6th cruising, when your hammering it then u go till the gear lever stops goin up
![]() I usually subconsciously count the gears anyway as i go up n down |
true, although if you use your sv enough you quickly learn the incredible noises your engine makes at different revs :P
#9 |
Trinity
A gear indicator is great! Much quicker than doing a calculation in your head based on revs and speed. Also stops you trying to change up or down when you ar already in 6th or 1st. Also good as just a confirmation say, checking you're in the gear you think you are before a corner. Don't knock it til you've tried one.
#10 |
haha fair enuf! Just doubt il own one for my sv but if people find them useful then I've got nothing against that!!!
Datatool digi gear | SUPERSTARDJ01 | Bikes - Talk & Issues | 5 | 17-11-09 11:34 PM |
gear indicator | auldyin | SV Talk, Tuning & Tweaking | 1 | 12-07-06 09:52 PM |
Gear Indicator | PWNDLOL | SV Talk, Tuning & Tweaking | 5 | 22-05-06 05:03 AM |
Datatool Gear Indicator | jimmy4237 | SV Talk, Tuning & Tweaking | 5 | 11-12-05 10:42 PM |
Datatool DiGi Digital Gear Indicator... | MitchC | SV Talk, Tuning & Tweaking | 15 | 03-06-05 02:53 AM |
