Old 26-01-10, 08:23 PM   #1
ricky
Default Rear brake pins - where from online?
hello all
in the middle of doing the rear caliper on the bike but need new rear pins as i cant get the old ones out.
cheers
Ricky
2001 sv650sk1 curvy
Old 26-01-10, 08:24 PM   #2
Default Re: rear brake pins?? where from online??
Wemoto
Old 26-01-10, 08:26 PM   #3
fastdruid
fastdruid's Avatar
Or tasty nuts I believe do titanium ones[1].
Druid
[1] Although I believe Ti is even worse for galling than Al, doesn't rust though.
Old 26-01-10, 08:44 PM   #4
5hort5
I sheared one off trying to get it out and then tried to drill it and missed, end of rear caliper lol, before buying the new ones just see if you can get them out without damaging other things first.
5hort5 is offline   Reply With Quote
Old 26-01-10, 08:49 PM   #5
sunshine
well 5hort5 is going to link you to his brake caliper thread so you know what NOT to do in this situation!
Old 26-01-10, 08:57 PM   #6
ricky
haha yer read that thread, i have snapped both pins, one on the tip and that one come out in a vise the other one snappe in the vise with about 4mm on the end
ended up drilling a small hole in the back and hammer it out
so deffo need 2 new pins now pmsl
Old 26-01-10, 08:59 PM   #7
5hort5
Here you go:
http://forums.sv650.org/showthread.php?t=145226
me and my muppet moment (one of just a few recently tbh)
Old 26-01-10, 09:03 PM   #8
5hort5
Yer sounds about the same as mine but I thought it would be a good idea to drill it from the front, bad idea now looking back on it, I should have measured it on the back and drilled there as the metal is softer. Having said that I'm getting a fully serviced set from husky for 25 quid and new pins will cost you 8.78 from wemoto
Old 26-01-10, 09:07 PM   #9
ricky
yer you are right funny you say that tho as thats the same pin that snapped at that size lol
any one priced up the pins at a local dealer??
Old 26-01-10, 09:11 PM   #10
5hort5
So are you going to clean up the good pin and reuse it, if so I have another - good (in need of a clean and rub down) pin, the one that didn't brake you can have if you just want a free option
rear brake caliper pins mattglavin SV Talk, Tuning & Tweaking 19 23-04-09 07:31 AM
Rear brake pad retaining pins. mikebrooman SV Talk, Tuning & Tweaking 8 23-02-09 08:03 PM
rear brake pins siezed - what now ejohnh SV Talk, Tuning & Tweaking 31 15-12-08 01:16 PM
Rear brake pins Viney Stuff Wanted 4 29-08-06 07:29 PM
rear brake pins syphonus SV Talk, Tuning & Tweaking 9 11-10-04 09:40 PM
