Old 16-04-10, 08:54 PM   #1
bigchris
Default rear shock tuning/setup for a big lad!!
right, just bought a 2001 sv650, and im going to be having the mrs on the back every now and then,
thing is im 20 stone, which i gather is too heavy for the stock shocks range of adjustment,
obviously the problom is worsened by a pillion passenger,
and i dont want our first ride out to be a bottoming out disaster!!
can anybody recomend a replacement shock from a 1000cc?
any ideas??
cheers,
Old 16-04-10, 08:55 PM   #2
Nobbylad
Nobbylad's Avatar
Default Re: rear shock tuning/setup for a big lad!!
Take off the pillion seat and replace it with a cowl.
Or buy a GoldWing
Old 16-04-10, 08:57 PM   #3
bigchris
cheers, quite helpfull that.
Old 16-04-10, 09:08 PM   #4
davepreston
gsxr 1000 shocks are used quite a bit which model im not sure or zxr1000 but do a search and it should pop up
hth
Old 16-04-10, 09:30 PM   #5
husky03
think plowsie had a busa rear shock on his due to similar prob
Old 16-04-10, 11:15 PM   #6
Nobbylad
Nobbylad's Avatar
Sorry - was just being daft...have people used Zx6 shocks before? As has been said, do a search for rear shock and there's a spreadsheet that lists spring rates of different shocks etc.
Old 17-04-10, 12:03 AM   #7
Preston
hey big chris, am no small guy my self do you mind me asking what size are you? so i know the best advise to give y athats all mate.. Also how tall are you as a simple jack up kit and work wonders for us big boys..
1st thing i would try is to get ya rear shock tool out ya sv tool kit " looks like a big Claw " and adjust ya rear shock so its on the 2nd from top notch, turning clock wise i.e on the left side of ya bike push away from ya best to have some one hold the bike when you do it as some times can be hard to turn it..
or try this, i have one an elka on its way Link : http://www.jhsracing.co.uk/suspension.htm
p.s if you also use a jack up kit no need to hack up ya battery box..
Old 17-04-10, 10:06 AM   #8
mjc
use the racetech spring calculator to find the ideal spring stiffness for your weight. then decide how much you want to change the ride height at the back, if at all. then follow the link below and find a shock that comes closest to your requirements for spring stiffness and length. then find someone on here whos used one and pester them about fitting.
youll also want to change your fork springs or you'll bottom out on the brakes, the racetech thing will tell you what you want. heavier oil might help the damping too.
racetech:
http://old.racetech.com/evalving/Spr...pringType=Fork
shock lengths:
http://forums.sv650.org/showthread.p...ght=rear+shock
Old 17-04-10, 04:09 PM   #9
Mr Speirs
Mr Speirs's Avatar
20 stone + pillion, it has got to be the busa shock. Zx10r spring rate might just be too soft.
The front springs will also need to be replaced, prob around the .95 or 1 mark.
GSXR shocks will all be too soft as the spring rates are less than the stock SV rate.
B1H shock setup Neeja SV Talk, Tuning & Tweaking 2 25-09-09 04:57 PM
rear suspension setup Frank Bikes - Talk & Issues 10 17-05-09 08:27 AM
rear shock nut and bolt for a diff shock drag Stuff Wanted 0 22-04-08 03:52 PM
PP Tuning Rear Sets Haxsaw SV Talk, Tuning & Tweaking 26 03-07-06 08:43 PM
Suspension/Shock setup advice please. Dante SV Talk, Tuning & Tweaking 13 13-08-05 06:46 PM
