Old 26-04-10, 09:35 AM   #1
N8te rider
Default Braided hoses - Which or dont bother?
Hi all
Wanna treat my baby and was thinking brakes. They work fine but would like a bit more bite/feel. Been reading through some threads and seems HEL can cause some problems.
Are braided hoses fairly easy to fit?
Are Goodridge the way to go, what would you recommend?
Or, if its not broke dont fix it and spend the dough on petrol?
Old 26-04-10, 09:43 AM   #2
neio79
Default Re: Braided hoses - Which or dont bother?
Hel are better than goodridge IMO, better price and all stainless steel . Goodridge you have to pay extra for alll ss fittings all over.
Old 26-04-10, 09:55 AM   #3
N8te rider
How many bits do you need to buy when replacing brake lines?
Old 26-04-10, 10:03 AM   #4
barwel1992
loads beter than stock, get hell and get the race kit comprises of 2 line both join the master cylinder with a dobble banjo bolt and run to each caliper seperatly
like this
fitting is the easy part its bleeding them that can be the pain
if you are going to go with braided lines i would strip the calipers down a well and clean thepistons and check the seals and grease the pistons with red rubber grease
i have these, they are the same as hell but are rebranded and made by the sellers on ebay (they also make custom lenght lines) Link
Old 26-04-10, 10:13 AM   #5
N8te rider
I used to do services on cars as a youngster. Is it the same process of pump brake pedal fast, hold, then release bleed valve (or whatever its called) and repeat until air is out?
Old 26-04-10, 10:18 AM   #6
I have goodridge on mine, they can be expensive with the fittings but i like them.
Cost about £80-£90 for front, cant remember exactly.
Old 26-04-10, 05:47 PM   #7
Miss_Undaztood
I`m sure I have, or had, trade accounts with Hel and Goodridge, i can see about prices if ya want.
Although from previous experience, some companies dont give much discount unless you spend a fortune, which I didn`t.
Old 26-04-10, 05:59 PM   #8
Dave20046
Dave20046's Avatar
£60 odd for stainless hoses & stainless fittings mine were goodridge but hel were only a few quid cheaper (that's for the front).
Bleeding's pretty straight forward (aslong as you understand the technique you're using) and fitting's a piece of pish. Copy how your existing ones are routed (leave them in for as long as possible during the fitting process)
Make sure you specify your exact bike when purchasing (including whether it's naked or 's'!)
Old 26-04-10, 06:01 PM   #9
Dave20046
Dave20046's Avatar
btw IIRC your bike is 2009? oem lines are good for 2 years (might be five actually). If it's 09 (sorry if I'm wrong) I'd try just a fluid change first or maybe some sintered brake pads a fluid change and a clean up of the calipers, save a little dough.
Old 26-04-10, 06:05 PM   #10
barwel1992
^ the ones i linked above are hel line just rebranded and are £40
Braided hoses Q metalhead19 Bikes - Talk & Issues 6 25-02-10 07:07 PM
Where to buy braided hoses? GOZA SV Talk, Tuning & Tweaking 13 28-03-09 05:49 PM
braided hoses hovis SV Talk, Tuning & Tweaking 11 18-11-06 11:04 PM
Braided hoses.. anything I should look out for ?? valleyboy Bikes - Talk & Issues 15 18-12-05 03:23 PM
Braided Hoses for a K4 wezza Ancillaries 3 09-11-05 09:54 AM
