Old 29-05-10, 01:28 PM   #1
rawiswaruk
Default Curvy doesn't tickover.
hello just got an sv 650 2000 the thing is after it gets warm the tick over is at 1000rpm but drops like it is going to cut out every few seconds and has cut out on me today, starts right back up easy enough. my bike has a beowolf can
here is a video of the rev counter with sound sorry about the quality was filmed on my phone the issue with the tick over starts around 10 secs into the video but is hard to hear on the video
YouTube Video
thank you
Old 29-05-10, 01:54 PM   #2
gettin2dizzy
Default Re: sv 650 tick over
Mileage?
Does it do it when cold/warm/hot?
Any recent changes to the bike?
Last service?
Carbs could just need balancing.
Old 29-05-10, 02:03 PM   #3
Tickover is too low my friend. Curvies tick nicely between 12-1400 rpm. This is why yours will cut out. Try to adjust this first and see if it makes a difference before feeling the need to do something more.
The way the needle is bouncing could indicate a carb balance is in order.
Old 29-05-10, 02:35 PM   #4
rawiswaruk
just got the bike yesterday, it only does it after the bike is warm it has a beowolf can on it
how would i adjust the idle also how would i go about balancing the carbs or is it cheap enough to let a garage do it
i am not that good with mechanics lol
thank you
Old 29-05-10, 02:37 PM   #5
Default Re: Curvy doesn't tickover.
There's a little black knob under the tank on the left hand side that adjusts the tickover speed.
If you haven't got any vacum gauges, get a garage to do the carb balancing this time
Old 29-05-10, 02:40 PM   #6
IIRC its around here somewhere
look for a small black flower shaped knob, cradled on the left hand side(as sitting on bike) This is the adjuster. Don't do it when the engine is cold, someone correct me if I'm wrong
Old 29-05-10, 02:55 PM   #7
rawiswaruk
will have a go at the idle tomorrow, out of interest what price would i be looking at getting the carbs balanced at garage?
thank you
Old 29-05-10, 02:59 PM   #8
dunno, sorry. I have a local monkey called Yorkie Chris that does it for small change, a packet of hobnobs and a barrel of tea!
Old 29-05-10, 03:01 PM   #9
thank you
Don't know as I've got my own gauges, its a bit of a fiddly job, because the take off for the front carb is tucked away.
Where are you? You might find an Orger nearby who's got the gauges to help you out
Old 29-05-10, 11:49 PM   #10
rawiswaruk
south normanton near j28 m1
barrel of tea do you have to buy that off the council lol
Tickover low and erratic. jonny.boyd Bikes - Talk & Issues 17 08-04-10 03:18 PM
12.4v at tickover, is reg rec knackered? -Ralph- SV Talk, Tuning & Tweaking 11 09-08-09 05:24 PM
No Tickover aermacchi SV Talk, Tuning & Tweaking 3 14-04-08 10:56 AM
tickover pin Hazzar Stuff Wanted 0 09-09-07 04:37 PM
missfire on tickover 01 sv650s SV Talk, Tuning & Tweaking 1 30-03-07 05:48 PM
