Old 07-07-10, 04:43 PM   #1
Pingu65
Unhappy Clunking noise - chain?
It's a VStrom not an SV650 but I think bikes are similar in respect to this fault.
Bike was a bit clunky sounding pulling away at various points of journey home.
Thought chain hasn't been cleaned for a while so maybe a link is sticking and needs a wash.
Before starting turned wheel and actually see rear sprocket moving as chain comes on and the clunk is the sprocket moving.
The centre rubber piece has come out...I can see ball bearings.
The sprocket itself is not seated inside rear wheel - which I think it should.
Garage tomorrow but just wondered what orgers thought it maybe and scare me with ballpark costs?
Old 07-07-10, 04:47 PM   #2
Mr Speirs
Mr Speirs's Avatar
Default Re: Any clues at to whats wrong?
Cush rubbers either worn or non exsistant...and if you can see ball bearings I would hazard a guess that the wheel bearing is gone too. If the above is correct do not ride the bike.
Old 07-07-10, 05:59 PM   #3
Kilted Ginger
oem rear bearings are about £10 each, plus labour, assuming the sprocket does not need replaced.
Did u manage to fix the topbox lock.
Old 07-07-10, 07:18 PM   #4
My local guy sells koyo ones (best quality you can get pretty much) for a fiver apiece.
There are 3 bearings in rear wheel assy, 2 in wheel, 1 in sprocket carrier.
Old 07-07-10, 07:22 PM   #5
Pingu65
Yep - Top box fixed a nut had fallen off the back of the lock (as you suspected).
Nicked nut of sidebox for now until I can get another one.
Thanks for sorting.
Old 07-07-10, 07:22 PM   #6
Pingu65
As I rode it home from work (26 miles motorway) - I assume the 2 miles to the garage will be fine.
Old 08-07-10, 05:01 PM   #7
Pingu65
Default Re: Clunking noise - chain?
All fixed - it was the 1 in sprocket carrier.
Happy biker again - thanks for the advice.
Clunking noise Grant66 SV Talk, Tuning & Tweaking 25 24-11-09 05:55 PM
It still makes that clunking fork noise. Tony_BLY SV Talk, Tuning & Tweaking 29 01-03-09 10:48 AM
clunking noise under braking nik_nunez SV Talk, Tuning & Tweaking 24 28-08-08 04:24 AM
Clunking noise on GSXR750 rubberduckofdeath Bikes - Talk & Issues 8 06-06-08 05:19 PM
clunking chain noise steveg Bikes - Talk & Issues 4 23-03-08 10:39 PM
