Old 10-07-10, 04:13 PM   #1
Joeskeppi
Default Bike fell off my stand, wonky fairing
Hi all,
I passed my test on Thursday and treated myself to a 2009 SV650 sport.
When I got home today, I parked it and then moved it forward an inch as it was touching the wall, and of course the stand went with it.
I'm totally mortified
So, loads of bits damaged, but the worst is that the left fairing is now flush against the frame, whereas the other side sticks out about 40mm.
Is there an easy fix for this? Looks like the bracket is bent.
I have pics:
Left (bent) side
http://img228.imageshack.us/img228/6205/img0619h.jpg
Right (straight) side
http://img268.imageshack.us/img268/4713/img0620sp.jpg
Other damage was:
The clutch lever was bent but that bent back into place.
The bar end is bent (the long screw that holds it in is bent)
The gear shifter broke, but I have drilled a hole in it and putt a bolt through with the old rubber on, so it works, got a new one coming Weds.
Lower fairing is all scratched.
I could have cried to be honest.
Old 10-07-10, 04:25 PM   #2
Default Re: Bike fell off my stand, wonky fairing
Been there, done that. Feel for ya chap
Worst one was dropping a 4x2 on the tank
Old 10-07-10, 04:28 PM   #3
Joeskeppi
Just fixed the bar end, nothing a hammer couldn't fix there.
Just worried about this fairing now.
Old 10-07-10, 04:31 PM   #4
ty_uk
Hi,
Did the same thing last year..just remove the fairings and gently tap out the brackets it worked for me.
Originally Posted by Joeskeppi View Post
Hi all,
I have pics:
Left (bent) side
Other damage was:
Old 10-07-10, 04:33 PM   #5
Joeskeppi
Cheers ty that's what I was hoping.
Is it easy to remove the fairings? Does the lower one come off on it's own? I can see 4 bolts to remove it I think.
Old 10-07-10, 04:51 PM   #6
ty_uk
just remove all 4 bolts and slip it out from top fairing..lower fairing joined at the bottom with plastic pins which i could not remove but was loose enough to get a mallet behind and tap bar back out
Old 10-07-10, 05:00 PM   #7
Joeskeppi
Thanks for that, very helpful
it seems to be the main curved bracket that would normally be where a crash bung would go, is this the one you straightened?
Did it require much of a whack or was it more of a progressive tap?
Old 10-07-10, 05:05 PM   #8
ty_uk
progressive tap, just take your time and should look like new again
Old 10-07-10, 05:05 PM   #9
Joeskeppi
Thanks for your patience, I'll have a go at that tomorrow then
Old 10-07-10, 05:07 PM   #10
ty_uk
yep the crash bung bracket is the one that takes the impact in a drop
Fell off my bike Stu Idle Banter 28 04-09-09 11:43 PM
My fairing lower fell off. Jamiebridges123 SV Talk, Tuning & Tweaking 16 13-06-09 11:04 PM
Bike fell off trailer while towed AndyW Bikes - Talk & Issues 9 30-05-09 08:28 AM
Bike fell, smashed indicator, not happy Tartan Terror SV Talk, Tuning & Tweaking 8 28-08-07 11:25 PM
Fell though roof and knocked over bike Grinch Bikes - Talk & Issues 34 11-04-06 09:13 PM
