Old 19-08-10, 10:12 AM   #1
Nick_69
Nick_69's Avatar
Default Rear Pre Load setting question.
This may sound a stupid question but i want to make my rear shock harder so i would want to increase my pre load right not decrease it
Was SV650S K9
Now GSXR 600 K9
Old 19-08-10, 10:32 AM   #2
christian1000
Default Re: Rear Pre Load
Yes. More pre-load = more compression on the spring = harder rear suspension
Old 19-08-10, 04:35 PM   #3
Not so.
Same spring, same load, same 'hardness'.
Preload does not change anything except where you are in the suspension's available travel under any given load.
Old 19-08-10, 05:23 PM   #4
Stu
Trinity
Stu's Avatar
Not so.
Doesn't preload reduce the the available travel by simply compressing the spring? - i.e. making it harder? That is intuitively how it works by looking at it, from a numpties POV i.e. me cf. you knowing how it works.
Old 19-08-10, 05:55 PM   #5
Default Re: Rear Pre Load setting question.
No.
As above, there's you the rider, that is; the load, apply that load to the spring it compresses the same amount no matter what you do to the spring setting.
Suspension is a dynamic system, the spring is not constrained to a given length in use - the length in use, (forget about that the suspension may 'top out' when you're not on the bike - you never use the suspension when you're not on the bike) is dictated by the load. Again; preload, (as previously discussed - the wrong word, but the one we have), adjusts ONLY the position in the available travel under any given load. Raising the preload does not make the suspension harder*.
Same spring, same bike, same load; same suspension stiffness.
Want harder or softer suspension? Change the spring/s, the only way.
*On the rear due to the way the linkage works raising the spring preload actually softens the suspension slightly as the linkage will be in a a lower part of the rate curve, by an tiny amount there's no doubt, but that is does so is not in doubt.
I did a series of pictures detailing how this works a while ago - I will need to find a suitable again bike to demonstrate beyond doubt what's happening.
Old 19-08-10, 06:00 PM   #6
barwel1992
Would increase the travel as the more preload the less the shock compresses under rider and bike weight so leaves more travel to be used when you actuly need it
Old 19-08-10, 06:34 PM   #7
Doesn't increase travel - only changes the position in whatever travel there is.
Old 19-08-10, 09:42 PM   #8
barwel1992
yeh thats what i was trying to get at
Old 19-08-10, 10:27 PM   #9
Never ride over a dip?
Old 19-08-10, 10:32 PM   #10
hongman
Ok, I'm going to be really thick here and demonstrate thati know feck all about how thus works.
Does a spring with equally spaced winds travel the same distance not matter how much it is already loaded?
I keep thinking that the more a spring is compressed the harder it us to compress it further.
Hence the assumption pre-loading a spring makes it stiffer.
Sorry. Noob.
Rear pre-load and shock length question DavieSV SV Talk, Tuning & Tweaking 1 14-06-10 08:46 AM
adjusting pre load rear jimmyb96 SV Talk, Tuning & Tweaking 5 09-11-09 07:53 PM
Rear Axle Torque Setting K6 Hardened Rider SV Talk, Tuning & Tweaking 3 01-09-08 09:51 AM
Rear Shock Hydraulic Pre-load Adjusters Luckypants SV Talk, Tuning & Tweaking 5 31-01-07 05:02 PM
rear sproket torque setting matsv650s SV Talk, Tuning & Tweaking 4 03-02-05 01:37 PM
