Old 14-09-10, 09:07 PM   #1
Tigerrrr.......
Default Car wheel nuts - grease or not?
I have a car with alloy wheels which should be torqued to 103.
Should I use grease/copaslip on the wheel nut threads?
Seems to be differing opinions.
Any advice appreciated. Thanks.
Be safe, be seen.
Tigerrrr....... is offline   Reply With Quote
Old 14-09-10, 09:17 PM   #2
svdemon
Default Re: Car wheel nuts - grease or not?
Yes but not on the hub faces
Old 15-09-10, 07:20 AM   #3
AndyBrad
yes on the rear of the wheel (hub) if you have alloys and threads. use copperslip not grease!!! and use sparingly.
Old 15-09-10, 07:43 AM   #4
Viney
My nuts are always greased. Had one to may issues with stiff nuts, and even snapping one off once! I also grease the hubs. Never done any harm. As said, use sparingly
Lithium grease / Castrol red rubber grease DarrenSV650S Bikes - Talk & Issues 25 22-01-10 09:59 AM
Can't undo Wheel nuts Stu SV Talk, Tuning & Tweaking 24 10-01-07 11:13 PM
Wheel axle grease type? muzikill SV Talk, Tuning & Tweaking 10 15-06-06 01:27 PM
Wheel bearing grease and filter oil big twin grin SV Talk, Tuning & Tweaking 2 05-03-06 10:16 PM
Grease me up! markfc SV Talk, Tuning & Tweaking 9 07-03-05 07:10 PM
