Old 30-10-10, 09:52 AM   #1
TeddyBearKing
Default Stalls after going into gear.
I changed the sprockets and chain last night, and it all looked good until I turned the bike on and tried to put it into 1st gear. The bike immediately stalled!!! I must have missed something somewhere, please help
Old 30-10-10, 10:00 AM   #2
dazzle44
Default Re: Stalls after going into gear! Please help!
sounds like something to do with the side stand switch maybe a wire has come off when you were changing the front sprocket
Old 30-10-10, 10:08 AM   #3
TeddyBearKing
That might be it! Cause I'm sure I put it all back right, I followed the haynes manual, cheers for the advice!
Old 30-10-10, 10:24 AM   #4
TamSV
TamSV's Avatar
It could maybe be the clutch dragging. Did you readjust after changing the front sprocket? To test, put the bike in first gear with the engine off and see if you can push it easily with the clutch in. If not, readjust clutch as per Sid Squid's regular posts on the subject.
Old 30-10-10, 11:48 AM   #5
TeddyBearKing
Cheers Tam, will check that too
Old 30-10-10, 03:25 PM   #6
Mr Meerkat
easy check for the sidestand switch, just give it a bit of beans on the gas with clutch in as you put it in first. if it still cuts out it'll be the switch...
Old 30-10-10, 03:39 PM   #7
TamSV
TamSV's Avatar
Definitely check the clutch isn't dragging first or there'll be an SV shaped hole in the back of the shed.
Old 31-10-10, 12:22 PM   #8
Mr Meerkat
yes!
Old 01-11-10, 11:20 AM   #9
Captain Nemo
Default Re: Stalls after going into gear.
was it the clutch?
Old 03-11-10, 08:48 AM   #10
TeddyBearKing
lol...cheers guys.
it was the side stand afterall, the side stand leg was not pushing in the switch, just needed some good oiling.
Checked the clutch too, needed adjusting...Haynes manual the rescue again!
Now rides nice and smooth.
I have another question for you tech heads tho. the locking washer on the front sprocket, I've not been able to bend it back down over the locknut. Has anyone else had this problem?
02 Curvy stalls at low revs allantheboss Bikes - Talk & Issues 60 15-12-09 09:43 PM
Stalls with scorpion Baph Exhausts 3 17-05-07 01:11 PM
Bike stalls when engaging first gear. SVChick SV Talk, Tuning & Tweaking 10 13-02-06 03:57 PM
Stalls and pops Mark_h SV Talk, Tuning & Tweaking 3 25-08-05 04:47 PM
