Old 09-12-10, 07:35 PM   #1
MisterTommyH
MisterTommyH's Avatar
Default Boiler issues!
Anyone know a few things about combi-boilers?
Came home on Monday to no heating and 'F1' flashing on the boiler. This was low pressure so I topped up to 1.5 bar and it's been ok.
Came home again tonight to the same thing and had to top up again. Heating was working both mornings when I left.
First time I thought was just a one off, but twice in a week?
Anyway it's taken a good hour and a half to raise the temp from 13 to 17.
Any suggestions of what it might be?
MisterTommyH is offline   Reply With Quote
Old 09-12-10, 07:40 PM   #2
Default Re: Boiler issues!
If its losing water pressure, its either you have a leak somewhere or the blow off is dumping a bit of water.
You should have a 15mm pipe outside coming fro your boiler, top it up and monitor this pipe see if any water is coming out.
Old 09-12-10, 08:59 PM   #3
Bluefish
I concurr lol, the pressure vessel is probably knackered, it's red usually on the back of the boiler has a car tyre valve on the top of it, if you take the cap off and press the nipple in, if water comes out you need a new one, if no water pump it up to .75 of a bar and fill system water pressure to 1 bar and see how it goes.
Old 09-12-10, 09:18 PM   #4
Albeit mate, you explained it more in depth, i have very limited knowledge of boilers tbh.
Best left to people like you who know what their doing
Old 09-12-10, 09:38 PM   #5
BigBaddad
Boiler giving you grief, time to kick her out.
Old 09-12-10, 09:45 PM   #6
MisterTommyH
Well it's run for about 3 hours now, and the pressures gone up to 2 bar?
I'll see if anything happens over the next few days. I'm hoping the pressure vessel isn't knackered as the house was only built in June!
Old 09-12-10, 09:51 PM   #7
Well in that case isnt the boiler under its 1 year warranty?
Dont waste time writing on here, phone the gits and get them to sort it.
Old 09-12-10, 10:01 PM   #8
MisterTommyH
Thats the plan, but I was wondering if there was anything more specific I could do tonight as they're not open till the morning. At least I won't freeze tonight tho as it seems to be working.
Old 09-12-10, 10:48 PM   #9
TSM
The Sick Man
TSM's Avatar
Pressure loss can be from anything not only the pressure vesel, yr rads could be leaking or pipework.
If it keeps hapening and you cant trace it, you could try some sealant that you inject into the system, have to be carefull to only get the type thats certified with combiboilers.
Old 10-12-10, 01:31 PM   #10
injury_ian
I have exactly the same issue, loosing pressure, no visible leaks.
So far this winter ive shoved over 20bars worth of pressure in it and yet to find a leak. takes a 2-3 days to loose all pressure, although its becoming quicker.
inspecting the pressure vessel today.
Is this boiler any good? BoltonSte Idle Banter 20 12-01-10 01:39 PM
Another Boiler Problem! DarrenSV650S Idle Banter 11 05-01-10 06:55 PM
Boiler Issues, again! Kinvig Idle Banter 8 20-12-09 03:36 PM
Combi-boiler advice JediGoat Idle Banter 19 14-02-08 01:50 PM
gas boiler has gone steveg Idle Banter 14 06-10-07 10:46 AM
