Old 03-01-11, 07:42 PM   #1
loonytoon
Default intermitant speedo fault
Yesterday i seem to have developed a intermitant speedo fault.
one minute it will work fine then all of a sudden just drops to zero then wont work for a few miles then comes back to life again.
has anyone suffered a similar issue ?
cheers
Ben
Old 03-01-11, 10:27 PM   #2
Default Re: intermitant speedo fault
The speedo drives are known to be easily broken if mishandled or incorrectly fitted - has the front wheel recently been removed?
If no, then check the wire from the drive to the clock first and if no damage apparent then it may still be worth removing the front wheel to check the drive. But as the fault is intermittent I'd first suspect a damaged cable or poor connections.
Old 04-01-11, 07:28 PM   #3
loonytoon
no the front wheel hasnt been out at all, it just stopped suddenly i was thinking it maybe a damaged wire but thought that it would stop completely.
i shall be pulling all of the plastcis off then to get checking.
Old 05-01-11, 05:22 PM   #4
Warthog
Same happened to me a few years ago, I'll try to find the thread...
Old 05-01-11, 05:24 PM   #5
Warthog
http://forums.sv650.org/showthread.p...ghlight=speedo
Hope that helps!
Old 07-01-11, 09:25 PM   #6
loonytoon
awesome dude cheers, after having a quick look over just the outer cabling i can see a couple of what appear to be pinch marks where the wire has been trapped in the past.
Think i may cut out the whole middle section an re wire it myself after checking its not just the rotor
Old 04-05-20, 07:51 PM   #7
Joe Yellow
Hi Ben,
does the tacho go to zero at the same time as the speedo, and the fuel light come on as the instruments re-awaken?
My 2000 S has been doing the same with increasing frequency over the last year. Most of the warning lights continue to work, except the fuel light and possibly over-heat. This shows that "switch-live" (orange-green wire) still working, so I concentrated on permanent live to the dashboard (red wire). Cleaned contacts in the connector block left of the headlamp unit and going into the instruments without success.
Latest trial is to re-solder some of the power connections in the instrument cluster. This now seems much more stable on a bench-test (tapping the instrument cluster it does not drop-out any more) but has yet to be tried on the road.
I will report again after a road test, and try to include photos of which connections to solder.
Help with speedo fault (common) on pointy Maverick9999 SV Talk, Tuning & Tweaking 2 13-12-10 07:03 PM
Intermitant brake light metalhead19 SV Talk, Tuning & Tweaking 4 29-01-10 11:13 PM
Intermitant problem monkimagic SV Talk, Tuning & Tweaking 11 14-10-09 03:42 PM
Speedo accuracy. If your '99 650 is showing 37mph on the speedo. lloyd_christmas SV Talk, Tuning & Tweaking 14 12-06-08 12:02 PM
Intermitant Engine not Starting TSM SV Talk, Tuning & Tweaking 6 16-07-05 05:21 PM
