Old 27-01-11, 10:01 PM   #1
Scareysurfer
Default New end can and K&N filter - fuelling changes?
Ordered a Beowulf stainless end can and a K&N air filter for my pointy 04 plate. Been looking on the forum and seen conflicting evidence of what I need to do as regards rejetting/re-tuning. Both Beowulf and K&N say I won't need to alter anything. Is this correct? Please help and advise!!!
P.S I will be running the exhaust with baffle in if that makes any difference.
Old 27-01-11, 10:32 PM   #2
davepreston
Default Re: New end can and K&N filter - fueling changes?
Well i dynoes my thou and strangely the k&n offset the no baffles sorting out my fueling according to the tester
Old 28-01-11, 08:16 AM   #3
Scareysurfer
Default Re: New end can and K&N filter - fuelling changes?
How much does the dump jetting cost roughly?
Thanks Scarey
Old 28-01-11, 08:17 AM   #4
Scareysurfer
Should read dyno, bloody iPhone auto completing!!!
Old 28-01-11, 12:33 PM   #5
johnnyrod
johnnyrod's Avatar
Just a run on its own will be around £30, if you want to mess around with new jets etc. then it depends how much time they'll need for it (buying a Dynojet kit isn't like a sticky plaster). For my 2pm, you can normally get away with adding K&N or noisy can and not rejet, although you won't get any improvements (to speak of). This doesn't mean it'll be running right, it just be running wrong enough to be a big deal, that's normally what they mean when they say it doesn't need rejetting (or it's just a stock replacement). If you'v eput both filger and can on then it's almost certainly worth rejetting it, and it might not run as well as befor eanywya, you'll know this better than me though.
Old 28-01-11, 12:40 PM   #6
Big Bad Al
Big Bad Al's Avatar
I stuck a Beowulf and K&N filter on mine a while back. Didn't have to do anything else. Bike runs lovely, sounds great.
SFV650 in black with Evotech tailtidy, R&G Aeros and Heated Grips, Puig fly screen, Pipe Werx GP style race exhaust. Whoop!
Previously.... Black SVS - DHM's Heated Grips Airblade Iridium Double Bubble Screen Beowulf end can and Evotech tailtidy. 3/7/2004 - 26/6/2015.
Big Bad Al is offline   Reply With Quote
Old 28-01-11, 12:45 PM   #7
bigchris
Hi, I put a Beowulf can on my curvey and was running lean as hell. So much so it was cutting out at idle. After searching on here and getting hardly any info I found this -
http://mickk.net/motorcycle/document...ting_Notes.pdf
This has really helped with my bike.
I read through it, then ordered some new main and pilot jets, fitted it all to the reccomended settings and it runs like a dream now.
The guide is meant for sv,s in oz but the stock settings are the same as uk.
As you will read in the guide you do have to rejett if you change can and filter allthough many people say you don't??
Have a read, hope it helps.
Big c
Old 28-01-11, 12:48 PM   #8
bigchris
Bike probably running lean. Not good for engine in long run.
Old 28-01-11, 12:49 PM   #9
Big Bad Al
Big Bad Al's Avatar
think that doc relates to carb'ed only?
Old 28-01-11, 12:51 PM   #10
Ruffy
Ruffy's Avatar
... pointy 04 plate. ...
No jetting issues, a pointy's fuel injected so no carbs.
Unless the pipe is really free flowing, i.e full race, I would expect the FI electronics to cope, but a dyno run to check CO/NO may give piece of mind.
On a pointy you can get the ECU remapped, so don't need to consider power commander etc., although I need others to advise where/how good etc.
Spannering the wife's SV650S K5 pointy in Black, and son's SV650 X curvy in Blue.
RIP SV650 X curvy, crashed and written off December 2019.
I'm (procrastinating about) fixing up an old Yamaha FZ600 to get myself fully back on the road.
Ruffy is offline   Reply With Quote
Altering FI fuelling? TheGreyWolf SV Talk, Tuning & Tweaking 2 05-05-10 11:10 PM
Fuelling problem? Toriiii33 Bikes - Talk & Issues 9 09-06-09 09:12 PM
fuelling up stanie SV Talk, Tuning & Tweaking 16 16-09-08 05:29 PM
Fuelling upgrade? gazza SV Talk, Tuning & Tweaking 1 09-05-08 07:21 AM
Fuelling Problems curium SV Talk, Tuning & Tweaking 2 15-06-06 02:15 PM
