Old 30-01-11, 12:52 AM   #1
Fluffer
Fluffer's Avatar
Default wrong chain
Went for a chain & sprocket set today and they didnt have the full set in stock, so just got the front sprocket and chain and said would grab a rear from another local place.
Wanted a middling DID x-ring (525 110) vm2? - with a 15t 45t listed at 89.99 in DK as the 'recommended upgrade'. Asked specifically for it but it got bagged up and handed to me and looking now its a DID50vx (530 112) - gold&black i did notice the 112 and go back and he said fine to just grind & remove which is a tad more work but didnt notice its a 530...
Right chain? wrong chain? Never heard of a 530 going on but dont know what difference it will make?
Grateful for advice
Fluffer is offline   Reply With Quote
Old 30-01-11, 01:26 AM   #2
rictus01
rictus01's Avatar
Default Re: wrong chain
the last number is the amount of links and a few to many isn't a major problem as they can just be chopped off, however the first number is to do with pitch/weight, the higher the number the bigger/beefier the chain will be, a number of racers will down grade to a 520 setup to save weight, or for something like a superduke/speedtriple it'll come standard with a 530.
it is possible to fit either a 520 or a 530 to an SV, but you'll need both sprockets and chain matched (as in all have to be the same number), but I wouldn't bother, take it back he's sold you the wrong one, the sv was designed for a 525 and that's what you should be fitting.
Cheers Mark.
anything wrong with ebay chain and sprocket kits? stuballs Bikes - Talk & Issues 27 15-07-09 08:12 PM
Chain / Sprocket Kit wrong parts delivered, do I keep? lazymanc SV Talk, Tuning & Tweaking 26 06-05-09 09:07 PM
What is wrong with my chain?! dmracing SV Talk, Tuning & Tweaking 17 26-07-07 04:14 PM
So what actually goes wrong with the cam chain tensors? svrash SV Talk, Tuning & Tweaking 10 25-06-06 12:19 AM
When wearing high heels was wrong, so wrong... Razor Idle Banter 6 03-06-06 08:51 AM
