Old 12-02-11, 08:25 PM   #1
Default Curvy Exhaust Stud size
Evening all
I'm just wanting to double check the size of the exhaust studs on the Curvies.
Went to replace the nuts to find the bugger was undoing the stud on both sides, grrr.
Any help is appreciated.
Also; is copperslip ok as an anti-sieze in the block?
Old 12-02-11, 08:27 PM   #2
barwel1992
Default Re: Curvy Exhaust Stud size
think they are m8's like on the pointy also coper slip is fine ps you can mix it with thread lock so they stick in as well but dont corrode in
Old 12-02-11, 08:30 PM   #3
cheers Dan
Had a feeling it was M8, but I don't trust pro bolts website with a few things
Old 12-02-11, 08:33 PM   #4
barwel1992
no problem
ohh they are m8x 1.25pitch i used 45mm long studs with 2 brass bolts one tightened against the manifold and then the other against the other nut
Old 12-02-11, 08:43 PM   #5
ideal!
Going to do the dealer ring round on monday, see if I hit lucky with someone with SS ones in stock
Old 12-02-11, 11:02 PM   #6
barwel1992
do! i said two bras bolts i meant nuts would be interesting putting 2 bolts in one hole (snigger)
Old 12-02-11, 11:12 PM   #7
sv650ollie
Yes copper slip is fine to use also silver paste.
And if the studs are undoing aswell put the stud in a vice then undo the nut from there .
then put it back on and tighten it up .
if the stud does not tighten it up properly then use two nuts do them up it will screw the stud back in .
hope that helps
Ollie
Old 13-02-11, 08:37 AM   #8
curvy custard
the bolts that hold the pillion handle work well too
Broken exhaust stud. barwel1992 SV Talk, Tuning & Tweaking 17 10-01-11 09:12 AM
99 (curvy) Exhaust Stud Things vardypeeps SV Talk, Tuning & Tweaking 9 31-10-08 08:59 PM
Snapped Exhaust stud! spacehog SV Talk, Tuning & Tweaking 4 22-05-08 08:21 PM
Whats the ehaust stud size for a pointy? DanF SV Talk, Tuning & Tweaking 3 15-05-07 12:39 PM
exhaust stud dirtydog SV Talk, Tuning & Tweaking 13 14-02-06 04:07 PM
