Old 10-03-11, 09:45 AM   #1
RavenWire
Default Do removable baffles affect economy?
this has been bugging me for a week or so now - but does a baffle affect the fuel economy of a bike? I swapped my curvy for a pointy 03 plate (only 4.5k on the clock) and the difference in mileage per tank is a little concerning - about 115 on the curvy to 88 on the pointy. Only difference is the baffle really as i'm guessing the alarm won't take up any petrol.
Cheers in advance
Old 10-03-11, 09:52 AM   #2
punyXpress
punyXpress's Avatar
Default Re: Baffles....
Caveat: I know nowt about pointies & precious little about curvies.
Isn't there a temp sensor which if not registering defaults the mixture to rich?
Now: Street Triple R
Old 10-03-11, 09:54 AM   #3
Stig
If anything I would have assumed the pointy being more economical. You've got issues I'd suggest. A free flowing exhaust isn't going to make dramatic differences on fuel consumption.
Old 10-03-11, 09:55 AM   #4
Should not make much difference.
Check the plugs and see if it is overfuelling, has the air filter got a dead cat in it or something, is the TPS and balance set OK? (they aren't from new!)
Old 10-03-11, 09:59 AM   #5
Bluefish
88 miles per tank, mr rossi i sugest you get a mechanic to have a look at it.
Old 10-03-11, 11:19 AM   #6
RavenWire
i wouldn't mind if its been sat for ages but its just had a service prior to the garage selling it to me. I don't ride it any differently to the other bike either - i'll have a word with the garage see what they can do.
Cheers for the help, greatly appreciated
Old 10-03-11, 11:39 AM   #7
SVMAT
That is certainly not the norm, so dont let em tell you it is. You should be seing 110 befor light comes on even with a heavy hand. As above its prob an easily fixed prob such as filter or sensor. Good luck!
Old 10-03-11, 12:49 PM   #8
Sir Trev
Sir Trev's Avatar
Hang on, back up a bit...
Do you really think the garage did anything more than clean it before selling it to you? They might have changed the oil so it looked nice and clean in the sight glass but do not assume they did anything like a proper service. Filters cannot be seen and you cannot tell if the throttle bodies have been properly balanced so they will often be left.
Complain to the dealer by all means but it's VERY easy to do these yourself, and then you'll really know.
Old 10-03-11, 01:05 PM   #9
mister c
mister c's Avatar
I have to say that I was shocked with the tank range on the thou, but I think that may be down to less than perfect servicing on the previous owners behalf. It does feel very sluggish & drinks more than Gazza on the binge. I'm getting about 90 miles to a tankful, the curvy gets around 150-160 miles per tankful.
Old 10-03-11, 01:07 PM   #10
husky03
shocking mileage to the tank mate-115 on the curvy?-my light fuel light started flashing last night at 137 and i've not been hanging around, 88 on a pointy would suggest something needs looked at-either its the bike or your ripping it up through every gear
higher compression - how would it affect A/F? barwel1992 SV Talk, Tuning & Tweaking 16 22-02-11 12:17 PM
How does the new tax rate affect you? gettin2dizzy Idle Banter 46 08-04-08 05:43 AM
The Budget - how will it affect you the_lone_wolf Idle Banter 40 13-03-08 04:36 PM
Alarm - Will it affect my warranty? Defender SV Talk, Tuning & Tweaking 9 19-01-08 10:27 PM
