how would higher compression effect air fuel mix ?
after doing pistons and gasket mod i think im running rich could just be me though ps air filter is clean and tb boots are fitted correctly v-stacks fitted and the same zorst as before only thing diff is pistons and thinner gasket thanks |
It should not affect it
ok cool, fuel economy is better than before just smells like fuel, will pull plugs at some point
ps running 99super |
What did you do Velocity Stack wise?
what do you mean ? i had them in before, running factory pro 70/35 midrange stacks
Could be something else random like the temp sensor keeping it on enrichment, also super is a bit denser which could affect it.
yeh head that the MAF (map?) (i think its called) goes as well ???
Well, MAF is mass air flow, I don't think SV uses one. MAP is manifold air pressure which it does use.
#9 |
#10 |
Well you have a few things on the go, could also be something daft like TPS needs doing. Or nothing at all and you got a whiff of petrol left over from cold start that just vaporised.
If it feels to run alright then pop it on a dyno and run it up, see what you get.
Do slip-on cans affect insurance? | Magnum | Bikes - Talk & Issues | 44 | 15-01-09 06:41 PM |
How does the new tax rate affect you? | gettin2dizzy | Idle Banter | 46 | 08-04-08 05:43 AM |
The Budget - how will it affect you | the_lone_wolf | Idle Banter | 40 | 13-03-08 04:36 PM |
Alarm - Will it affect my warranty? | Defender | SV Talk, Tuning & Tweaking | 9 | 19-01-08 10:27 PM |
