Mini-Twins Goto Minitwins Official Site
Old 11-05-11, 06:52 PM   #1
Hefyn18
Default Tip Over sensor issues, please help!!
iv had my ecu off while i was taking the subframe off and now it wont start, iv done a bit of a diagnostic and the error code is saying c23 which is tip over sensor. but im not sure what it looks like. or how to re-set etc. any help would be greatly appreciated as im racing on saturday and im in quite the jam.
Old 11-05-11, 09:17 PM   #2
-Ralph-
Default Re: Tip Over sensor issues, please help!!
It's a small black rectangular box which hangs off a few cables, in a rubber sleeve, and normally it should be slotted by the rubber sleeve on a small bracket on the front of your battery box, if it's hanging loose or not the right way up the bike won't start.
Old 11-05-11, 09:24 PM   #3
-Ralph-
If you were to draw a clock face on this picture, the tilt switch is at 1 o clock just peaking out underneath the tank, with a red wire running into it.
Old 12-05-11, 12:05 PM   #4
muzikill
muzikill's Avatar
It's just behind the rear brake resovoir and in front of the tank hinge, it'll be very dark in there. shine a torch in and you see a rubber block with wires coming out the back of it.
Read the official manual for error diagnosis (c23 error) and follow the instructions on how to test it. If you want a replacement off ebay it'll be around £12-25 and take around 5-7 days for delivery. If you want it quicker it'll be around 40-55 quid new from a suzuki garage part dept. (yes really!), so i'd suggest to test it first just to make sure!
Im sure theres a way to bypass it, but it will involve a resistor and some wiring skills and it's not recommended especially if your racing and you have an off.
Im in the process of getting a replacement one myself after the test failed on it
Tip Over sensor issues. Hefyn18 Bikes - Talk & Issues 2 12-05-11 12:40 PM
Tip Over Sensor Frogman Stuff Wanted 0 27-03-11 05:34 PM
Speedo issues, GSXR front end, hall effect sensor? DavieSV SV Talk, Tuning & Tweaking 4 06-03-11 07:50 PM
Tip Over Sensor US Model Stephen_ver4.0 Bikes - Talk & Issues 2 04-09-09 08:41 PM
fuel sensor noob-saibot SV Talk, Tuning & Tweaking 9 26-08-09 03:14 PM
