Old 16-06-11, 12:43 PM   #1
cy8rm4n
Default Gear knobby thing
Sorry don't know it's right name, it's basically a bolt with rubber on it sitting at the end of the lever for you to flick with your toe. Riding along yesterday when as I changed up I felt it pop off. Luckily I was able to find it & screw it back on, may not be so lucky next time. It just seems to be a screw fitting that's worked loose.
Is this a common problem & should there be a bolt at the other end of it to stop it doing this?
Old 16-06-11, 12:44 PM   #2
BBadger
Default Re: Gear knobby thing
Thread lock is your friend.
Gear Shift Rod bent - Gear Changing problem Thaleshwar SV Talk, Tuning & Tweaking 13 05-06-10 06:28 PM
gear selector rod thing husky03 Stuff Wanted 7 31-01-08 07:02 PM
Gear lever rubber (toe thing) K5 dmracing Stuff Wanted 0 21-06-07 10:27 PM
Anyone used these before (gear sack thing) pups3000 SV Talk, Tuning & Tweaking 8 18-05-07 04:31 PM
Gear link rod thing.............. svrash SV Talk, Tuning & Tweaking 1 19-12-05 12:30 AM
