Old 28-06-11, 03:13 AM   #1
Runin2Hot
Default Hello and charging fault.
Hi my name is Matt and I'm new to the site. In febuary I bought a 01' SV 650. This is my first bike other than a dirt bike several years ago. I am a daily rider and it's my only transportation. I love it!!!! However, I am having some troubles. I have been throug 2 batteries and have since had the charging system tested and was told my voltage regulator is bad. I am pretty good with cars, but I am totaly out of my element with this. So now I turn to those of you veterans for some advice. I have been told that there is a gen1 and gen2. Not sure of the diference. Now I have a voltage regulator but have been told Its a gen2. (I confirmed this by actualy looking at the new one versus the old one) the plugs are different. I was told that this would work but just needs to be re-wired. I guess my question is, is it possible to switch the plugs? Any advise is greatly appreciated. Thank you very much for your time in this matter. Ride safe. Matt
Old 28-06-11, 05:42 AM   #2
mister c
mister c's Avatar
Default Re: Hello all. New to the site from Bradenton
Howdo & welcome to the site. Good choice of bike too
Answer to your question is, yes you can fit the gen2 (pointy) reg/rec. A little bit of soldering & it is quite easy.
This picture isn't that good, but you can just about make out the plug swap. Hope it helps & enjoy the SV
Old 28-06-11, 08:00 PM   #3
Runin2Hot
Thanks for the advice. I'll give it a try.
Charging fault - which reg/rec? eddyb SV Talk, Tuning & Tweaking 27 01-04-10 11:04 PM
Charging fault? Spanner87 SV Talk, Tuning & Tweaking 20 03-03-10 06:20 PM
Charging fault? emcf SV Talk, Tuning & Tweaking 10 28-11-09 03:03 PM
Charging fault? Sorehead Rex SV Talk, Tuning & Tweaking 8 18-11-09 09:31 PM
What sort of multimeter do I need? - charging fault. RobH13 SV Talk, Tuning & Tweaking 21 13-10-09 01:15 PM
