Old 05-07-11, 08:23 PM   #1
muzikill
muzikill's Avatar
Default 12v power socket kits
http://forums.sv650.org/showthread.p...02#post2568602
Just in case some people miss this since theres been a few threads on doing this ive posted a thread in ancilliaries about these. Might make it easier for people to do and those who never thought about it until now.
Towzatronics 12v power socket kits muzikill Ancillaries 2 06-07-11 10:57 AM
Power Socket Bluefish Bikes - Talk & Issues 12 12-04-10 09:44 PM
Just added a power socket TC3 Bikes - Talk & Issues 15 12-07-09 09:52 PM
Wiring a power socket? DEJA_Vu SV Talk, Tuning & Tweaking 7 02-02-09 12:18 AM
12v power socket? Baldyman SV Talk, Tuning & Tweaking 14 20-05-05 04:55 PM
