Old 27-12-11, 05:45 PM   #1
W4tto
Default Indicator wiring error?
Just a quick one.. I hope
Fitted new indicators front and rear and now they're flashing double speed although I'm certain they're wired correctly.
Flash normally on hazard but double on indicator. All bulbs are ok and fuses too.
Someone please correct my simplistic stupidity for me..
Thanks boffins'
Tom..
Old 27-12-11, 05:49 PM   #2
TSM
The Sick Man
TSM's Avatar
Default Re: Indicator wiring fook-up?
LED indicators?
If yes then you need some resistors.
If not then the wattage on the bulbs are wrong and you also needresistors as well or change the bulbs to the correct wattage specified in the SV manual or look at the old bulbs.
Old 27-12-11, 05:53 PM   #3
Originally Posted by TSM View Post
LED indicators?
This seems to be the latest quick fix for LED indicators, a better option than individual resistors, especially if you've got front and rear
http://www.ebay.co.uk/itm/4002501242...ht_1350wt_1139
Plug & play - simples
Old 27-12-11, 05:56 PM   #4
TSM
The Sick Man
TSM's Avatar
yup thats better and you wont end up having to cut/splice anything or worry about resistors running very hot
Old 27-12-11, 06:08 PM   #5
W4tto
Cheers folks,
And wiring this in will cure the problem all round with having led front and back?
Old 27-12-11, 06:10 PM   #6
Originally Posted by W4tto View Post
Cheers folks,
Yep, just unplug the standard Suzuki relay and plug this in its place, its that simple
Old 27-12-11, 06:45 PM   #7
W4tto
Thanks a lot. Much appreciated!
Old 27-12-11, 09:11 PM   #8
-Ralph-
Default Re: Indicator wiring error?
I have an LED relay going spare, yours for a fiver via paypal, never been used as it doesn't work on my Triumph.
Sv Indicator Wiring Spoonie Bikes - Talk & Issues 2 13-12-11 03:12 PM
Aftermarket indicator wiring? Murph SV Talk, Tuning & Tweaking 2 22-10-11 04:52 PM
Quick indicator q (wiring) Baph SV Talk, Tuning & Tweaking 6 01-04-08 04:22 PM
LED Indicator Wiring rob13 SV Talk, Tuning & Tweaking 5 23-01-06 08:07 PM
