Mini-Twins Goto Minitwins Official Site
Old 12-01-12, 03:40 AM   #1
SVSteve1
Default What kind of shock are you running?
I'm cheap and don't want to spend tons of money on a new shock. A lot of the guys in the US run a used 636 shock. I'm a fat old fart so I'm running a ZX14 shock on my SV. It's adjustable, a really good swap (length and stroke) and it comes stock with an adequate spring for a fat old man. Almost everyone here at least starts out with a better shock (used) off another bike before going to a top of the line aftermarket shock. I'm just curious what you fellows over here are running.
Old 12-01-12, 11:56 AM   #2
TOLAROS
Default Re: What kind of shock are you running?
Penske.Just get it,you'll have a different bike.
Old 12-01-12, 12:22 PM   #3
carelesschucca
carelesschucca's Avatar
I didn't race but I got a nice WP shock for my SV. I got it 2nd hand from someone on here and it transformed the bike. It was adjustable for length so I ran it slightly (15mm) longer than the standard, it made the back end way more planted and the turn in was a lot quicker.
I put WP springs in the front changing the oil and by the end had them dropped through the forks by 10 mm.
For me it improved the bike.
Old 12-01-12, 11:04 PM   #4
AZZ3R
I've had the idea about putting either Hagon, Ohlins or Hyperpro fork springs.
Now I don't know if it will make that much off a difference to the front end?
Also debating wether to change the rear shock or not.
Old 13-01-12, 02:16 PM   #5
Bigmitch
Hi Steve, Im running an Elka rear shock, with k-6 GSXR-600 USD forks K-Tech'd re-spring re-valve piston kit, works for my 14st frame :0)
Old 13-01-12, 02:25 PM   #6
NTECUK
NTECUK's Avatar
Yes That and the oil.
Old 13-01-12, 06:33 PM   #7
SVSteve1
There are lots of people that never ride their SV hard enough to notice the suspension's failings. Unfortunately the suspension is the biggest place that Suzuki saved money. If you race or even ride aggressively on the road, at some point you will decide that you want to upgrade the suspension. You need to upgrade the shock and forks at the same time. If you upgrade just the forks, it will make the shock act worse. Same with the shock. A better shock will show just how poor the forks are.
If you're road riding or your rules allow it, a used Gixxer USD front end is your best bet. My rules require me to race the original fork lowers, so it gets better springs, emulators and oil. After this expense, I couldn't afford an aftermarket shock, so I have a used ZX14 shock which is a big improvement until I have scratched up the money for a new or used aftermarket shock.
Just saw a hit an run...kind of. poisonidea Bikes - Talk & Issues 45 02-04-11 06:05 PM
running problem - as if running out of petrol Nick8529 SV Talk, Tuning & Tweaking 20 27-10-09 11:47 AM
Some kind of running light. Sean_C SV Talk, Tuning & Tweaking 11 24-12-08 06:26 PM
Running rough, running out of ideas. Sarj SV Talk, Tuning & Tweaking 17 04-12-07 06:45 PM
Would the tax man be kind to me? enginedriver Idle Banter 9 07-12-06 06:54 PM
