Old 21-02-12, 12:04 PM   #1
robbie09
Question SK5 - Mid Engine Mounting Bolt bent!
Well in a crash that occurred some time ago i managed to bend one of the crash bungs that was on the bike when i bought it.
I've finally got round to drifting the bolt that it screws on to out and found it to be bent
I'm not really sure what is standard on my bike :S I currently have a bent double ended (each with a thread) mounting bolt that feeds from one side of the frame through the engine and through the other side of the frame...
Im not going back to original...ive just bought some R&G bungs but the bloke at demontweeks didnt know what they were mounted on or whether or not it came with a bar to shove through the engine that the bungs screw onto. ....
Stuck!
Old 21-02-12, 12:30 PM   #2
jambo
jambo's Avatar
Default Re: SK5 - Mid Engine Mounting Bolt bent!!
I'm pretty sure the standard part would be a nut & bolt that go through the frame & motor. The double-threaded item would probably be an R&G part, give R&G a call, they'll be able to confirm for certain.
http://www.rg-racing.com/browseBike/..._%28K5%29.aspx
This suggests that the R&G product would replace 2 engine bolts?
Jambo
Old 21-02-12, 01:03 PM   #3
robbie09
I bought the bungs of R&G originally on the 6th and had to cancel my order today because i hadn't received any communication from them at all ;(
Apparently i would have been waiting till next Wednesday at the earliest to get them...
Ill give R&G a ring...fingers crossed he's clued up!
Old 21-02-12, 01:30 PM   #4
jambo
jambo's Avatar
Have a check on the OE Microfiche:
http://www.ronayers.com/Fiche/TypeID...8/Model/SV650S
Jambo
Old 21-02-12, 07:18 PM   #5
robbie09
Thanks for the help Jambo!
Gave R&G a ring and apparently the bungs come with a replacement rod. Hopefully it will all go swimmingly *fingers crossed*
cheers
Old 22-02-12, 10:08 AM   #6
jambo
jambo's Avatar
Good luck, God bless
Snapped engine mounting bolt. toby_smith SV Talk, Tuning & Tweaking 6 13-04-10 09:26 AM
Engine Mounting Bolt. Curvy toby_smith Stuff Wanted 1 11-04-10 04:23 PM
Engine mounting bolt disaster. gfewster SV Talk, Tuning & Tweaking 9 09-04-10 08:10 PM
Stacked it - has crash bung bent engine bolt? skyline Bikes - Talk & Issues 10 01-02-10 10:42 PM
Engine mounting bolt HELP PLEASE!!!! DeeJay SV Talk, Tuning & Tweaking 18 05-11-04 09:48 AM
