Old 09-03-12, 07:20 PM   #1
Andy17898
Default 12,000 mile service - what needs doing?
Guys, i have no service history with my bike, and have owned it for three or four years, in that time its had a minor service, but had no reciept.
What needs doing in terms of service now? Its a 53 plate and has done 12k miles.
Second question, is there a kit you can buy with service parts cheap? and is it easy enough to do yourself?
cheers
andy
Old 10-03-12, 12:27 PM   #2
keith h
Default Re: 12,000 mile service - what needs doing?
Hi Andy, if it were me I would give the bike a good going over.
i.e. oil & filter change, air filter change, coolant change, brake fluid change, spark plug change, chain clean & grease + adjust as necessary.
Oil all linkages etc
All of these items are fairly easy to do and could save you a tidy sum.
When the air filter is out check throttle plates free of muck
Remove brake pads front & back & inspect for wear, check pistons moving ok.
Check all nuts & bolts for tightness.
Last but not least check tyres for condition & pressure
There are service kits on the bay but check for quality, get a genuine oil filter if poss. Should you need brake pads get a reputable make. regards Keith h
Old 10-03-12, 12:41 PM   #3
Andy17898
Thanks keith appreicated. Ive seen the HI-FLO kits on ebay, with plugs, air and oil filters.
They any good? If so will pick one up and give it a go?!
Old 11-03-12, 03:21 PM   #4
keith h
Hi Andy, thanks for reply. No doubt thse HI- FLO kits are ok so no harm in giving them a go, most members on here would go for NGK plugs. cheers Keith h
4,000 mile service Nobbylad SV Talk, Tuning & Tweaking 7 30-09-08 09:16 AM
7,500 Mile Service....... SoulKiss SV Talk, Tuning & Tweaking 9 15-06-07 06:13 PM
20,000 mile service £110 hovis Bikes - Talk & Issues 12 11-06-07 01:58 PM
15,000 mile service peanut SV Talk, Tuning & Tweaking 11 06-06-07 06:33 PM
8,000 mile service 22 SV Talk, Tuning & Tweaking 1 04-06-05 03:53 PM
