Old 11-03-12, 07:40 PM   #1
super mario
Default Brake fluid level?
Hi,
My brake fluid on the front is running low, but as I start to brake the fluid from the reservoir seems to almost all but disappear, is this normal and just because the fluid is low?
Thanks
Old 11-03-12, 07:54 PM   #2
Default Re: brake reservoir
It's a liquid - when you brake it runs to the front*.
If it's below the line when the reservoir is perfectly level, (in both planes), top it up.
*PS. When you're braking stop looking at the brake cylinder - watch where you're going.
Old 11-03-12, 07:58 PM   #3
super mario
Thanks, I did think that.
It was one of them things, it caught my eye and I could'nt help notice it all the time.
This might be a bit of a dumb question but do I need to bleed the whole system or is topping it up fine.
Old 11-03-12, 08:06 PM   #4
Default Re: Brake fluid level?
No, as long as the level hasn't dropped below the minimum and there's no question of air having entered the system, it can just be topped up. That said, if the fluid is old or the age is unknown complete replacement is advisable. Particularly as brake fluid is so cheap.
Bear in mind that low fluid is often a sign of worn brake pads.
Old 11-03-12, 09:49 PM   #5
embee
embee's Avatar
Worth just mentioning that to top it up you remove the cover and then remove the rubber diaphragm to get to the fluid, it has been known for some folk to add fluid into the diaphragm not into the reservoir!
Remember that brake fluid is very harmful to painted surfaces, always cover up the surrounding paintwork with rag in case of spillage or drips. Have a sponge and some water handy in case of spillage, wash it off paintwork as soon as possible and it'll be OK.
As Sid says, it's recommended to change brake fluid now ansd again as it absorbs moisture from the atmosphere and generally gets contaminated (even though the system is "sealed"). Change it every couple of years ideally (or sooner).
Old 11-03-12, 09:51 PM   #6
super mario
Thank you both for your help. Im quite a newbie to bikes so just want to get it all right.
bleeding brakes, fluid level pencil shavings SV Talk, Tuning & Tweaking 17 19-03-09 11:19 PM
Brake Fluid Resevoir Diaphragm and level check branny SV Talk, Tuning & Tweaking 11 27-01-09 04:11 PM
Brake Bleed nipple/Mityvac/Brake Fluid query Ceri JC SV Talk, Tuning & Tweaking 15 20-01-09 02:04 PM
Brake fluid level issues bigE SV Talk, Tuning & Tweaking 1 01-03-06 08:16 AM
Master brake cylinder fluid level after bleeding? kinesin SV Talk, Tuning & Tweaking 1 12-07-05 07:40 PM
