Old 08-06-12, 08:27 AM   #1
Fifteen15
Default Removing glue marks on dash surround?
I stuck my heated grips controller to the black plastic on the left of my rev counter with super glue because the adhesive that came with it kept coming off. Today I peeled the controller off because I have some new heated grips but it left loads of super glue stuck to the plastic. I tried getting it off with nail polish remover but that just made things worse. Now I'm left with a messy stain next to my rev counter.
So what are my options? All I can think of is sticking the new heated grips controller over it to cover it, or stick a sticker over it. Both which I don't really want to do.
Any ideas Orgers?
yuk yuk yuk
Old 08-06-12, 08:46 AM   #2
Owenski
Default Re: Made a bit of a mess...
Remove all the black plastic surround, buy another one, fit the new one. Works 100% every time.
Sorry Im sure someone with a more reasonable solution will be along soon enough.
Old 08-06-12, 08:52 AM   #3
flymo
flymo's Avatar
You may be right. With Superglue you get a chemical bond between surfaces, not just some sticky glue that can be removed.
What material was the grip controller surface made of?
Old 08-06-12, 09:01 AM   #4
Shawthing
Shawthing's Avatar
http://www.maplin.co.uk/debonder-46000
Might work.
SK9 Sport Black Delkevic can.
Old 08-06-12, 09:03 AM   #5
pookie
pookie's Avatar
dunno try vinyl bumper polish , black boot polish maybe to cover it
Old 08-06-12, 02:30 PM   #6
Geese
if all else fails... PB sticker!
Old 08-06-12, 05:11 PM   #7
shonadoll
Try a good car trim reviver such as autofinesse revive, or there's a plastic renovator called plasti Kote which comes in spray or liquid form, available on eBay £15 a tin cheaper than a new thingy. Make sure and clean well first.
Old 08-06-12, 05:45 PM   #8
Nobbylad
Nobbylad's Avatar
These surrounds sometimes come up on fleabay for around £20. It doesn't affect the function of the bike so I'd be inclined to leave it as it is (says the man with a gold CNC clutch cover with a window in it )
Old 08-06-12, 06:27 PM   #9
Fifteen15
Thanks for the help. Decided to just stick the heated grip controller over the messy part. Doesn't look as bad as I first thought it would. Thanks again for the help!
Old 09-06-12, 10:09 AM   #10
Dabteacake
Try a little petrol on a rag that's quite good at removing stickers lol
Marks on tank - why and what can I do about it? SIII SV Talk, Tuning & Tweaking 28 09-09-10 06:11 PM
removing tank pad and glue sv_steve SV Talk, Tuning & Tweaking 10 01-03-08 04:56 PM
Water marks Skip Bikes - Talk & Issues 11 16-05-06 10:27 AM
