Old 26-06-12, 08:21 AM   #1
Fozzy
Default Gear shifter spindle
Just need some advise please.
I've noticed some play in the shaft that holds the lever on.
Is it screwed in place?
Sent from my GT-I9100 using Tapatalk 2
Old 26-06-12, 11:28 AM   #2
Fozzy
No one?
Old 26-06-12, 11:37 AM   #3
Jayneflakes
Jayneflakes's Avatar
Default Re: Gear shifter spindle
Sorry, my K3 is done a different way, so can't help.
It sounds like you could be the one to discover the answer. Pop the circlip off and check the bearing material that your lever is running on, if it is similar to the K3, it is just a woven fiberglass type thing and will need cleaning and greasing. They do wobble though and I am not sure that they can be replaced.
As for your pin, my guess would be a shrink fit or rivet, but you never know, it may be bolted in. Photograph your progress and see how you go.
Jayne you're a Pussy Magnet
Old 26-06-12, 11:42 AM   #4
Fozzy
The shift lever is new i can see the black part move about 2mm up and down.
Im at work atm so can't play with it. Im hoping its got some thread and an allen key hole on the inside.
Old 26-06-12, 12:01 PM   #5
Nobbylad
Nobbylad's Avatar
Old 26-06-12, 12:09 PM   #6
SoulKiss
SoulKiss's Avatar
Beware if you unbolt it.
There were a bunch of K6's that unbolted themselves in use (mine was one of them) leaving the lever hanging by the rod and no way of changing gear.
Just make sure you do it up again nice and tight
Old 26-06-12, 12:26 PM   #7
Nobbylad
Nobbylad's Avatar
Loctite may be an idea then.
Old 26-06-12, 12:40 PM   #8
Fozzy
Thanks so much guys.
I'll be careful on my way home.
It has flats so I'll thread lock it too.
Again thanks
Old 26-06-12, 01:26 PM   #9
Nobbylad
Nobbylad's Avatar
For future reference http://alpha-sports.com/Parts/SM05.htm
Old 26-06-12, 02:04 PM   #10
Fozzy
Thanks nobby.
Desperaley need a k6 gear shifter joshwalker094 Stuff Wanted 15 19-12-11 09:38 AM
Curvy gear shifter JamesMio Stuff Wanted 3 28-02-11 05:21 PM
Goodby Gear shifter :( hob SV Talk, Tuning & Tweaking 7 18-11-08 05:29 PM
Is it not possible to get the gear shifter off the footpeg assembly? Jase22 SV Talk, Tuning & Tweaking 3 17-08-08 06:15 PM
Gear shifter linkage rod Razor SV Talk, Tuning & Tweaking 5 05-01-07 11:26 PM
