Old 17-10-12, 07:24 AM   #1
punkyp
Default Pointy weeping radiator
Hi,
Over the last couple of days I have noticed my radiator is weeping from some where, not sure where, it isn't easy to spot.
Would you lot suggest radweld or somewhere in Sheffield area that can repair it? Too skint for a new/used one.
In the mean time I am carrying round a bottle of antifreeze mix to top before my next ride to/from work. It isn't a spurt, just a drip every couple of seconds and only during/after a ride, is this a bad idea?
**EDIT**
Could a mod correct my title please?
Old 17-10-12, 09:36 AM   #2
hardhat_harry
Default Re: Ponity weeping Radiator
Nip up the jubilee clips first it may be coming from where the hoses meet the rad
Old 17-10-12, 09:43 AM   #3
punkyp
I will give that a bash, some of the fins are wet so I just assumed it was in that general area. Cheers
Old 17-10-12, 09:59 AM   #4
jambo
jambo's Avatar
This thread may be worth a read.
Jambo
Old 17-10-12, 10:10 AM   #5
punkyp
Jambo
cheers, mine is not that bad, I can't even see where it is, any tips on finding it to have a bash at the the repair? Don't to go removing fins willy nilly to look for a crack/hole.
Old 17-10-12, 03:50 PM   #6
jambo
jambo's Avatar
With the system full, and the radiator dry, add some talc powder, start the bike up and watch where it gets damp first.
Old 17-10-12, 04:53 PM   #7
punkyp
Excellent idea, I'll try that later thanks. Went from full to low on ride home so I can't ignore it.
Old 17-10-12, 07:17 PM   #8
punkyp
5 spots went damp around the same time
Old 18-10-12, 09:07 AM   #9
jambo
jambo's Avatar
Assuming those 5 spots are all separate on the rad core, and water isn't flowing along the back to emerge at 4 or 5 places at the front, I'd take that as a fairly clear indication that the radiator is past saving.
Aaron & Delkevic both make replacement rads that I suspect are cheaper than OE as listed in that other thread. That's what I'd do.
I'm sure you could use radweld, and maybe it would work for a while, but I really dislike products that work in that fashion as they're blunt tools that could end up gumming up coolant passages if you got unlucky. You're going to have to replace it anyway, just bit the bullet and do it now.
Jambo
Old 18-10-12, 09:18 AM   #10
punkyp
Jambo
Called a few local breakers, one has a 2000 radiator in, but I'm pretty sure that won't fit from my internet research.
Oil weeping from valve cover. DarrenSV650S SV Talk, Tuning & Tweaking 18 03-03-12 07:59 PM
Weeping Fork Seal plowsie SV Talk, Tuning & Tweaking 12 15-04-09 02:54 PM
Pointy Radiator Fan RGV250ads For Sale - SV's and SV related items 0 26-06-08 06:02 PM
pointy Radiator ? hovis SV Talk, Tuning & Tweaking 3 19-06-08 07:31 PM
weeping nipples :-0 flymo SV Talk, Tuning & Tweaking 21 10-03-08 06:38 PM
