Old 17-12-12, 09:38 PM   #1
lawson17
Default Valve clearances - K3.
Today I checked my k3's valve clearances. The front cylinder was all spot on. The rear however wasn't. The smallest feeler I had is 0.05mm. Which wouldn't go under any of the inlet or exhaust cams.
Before I go changing shims to suit, is it normal to have all four be so far out? On one cylinder? Or am I overlooking something else important...
The current shims are 1.8mm an 1.7mm. If the 1.7's aren't worn I plan to swap them to the other side to give at least the required 0.1mm gap. Then put 1.50's in place of the 1.7's to gap them appropriately.
I should also mention that this bike is only used for racing and is the first time I have personally checked the clearances.
If anyone can shed any light on the subject that would be great. Thanks.
Old 18-12-12, 10:29 AM   #2
tim8061
Default Re: Valve clearances
You deffo got the timing marks in the right place to check the rear?
Old 18-12-12, 10:39 AM   #3
Mark_h
Mark_h's Avatar
Has anyone got any pointers on indicators of mal-adjusted valves? I've never checked mine but currently everything is running fine. Do you get common symptoms of gap issues?
How much of a pain is it to check them? I understand adjusting is a lot trickier than checking but just looking for a little guidance.
Minister for Sustainability
Old 18-12-12, 11:36 AM   #4
k1ngy SV
Be amazing if someone made a youtube guide how to do it.. while they do theres
Old 18-12-12, 11:36 AM   #5
Rokerman
Can't answer your question but watching with interest.
Mine are due (14K) but I'd rather wait for the next service.
Old 18-12-12, 11:38 AM   #6
You can't tell, you have to check them.
Old 18-12-12, 11:58 AM   #7
k1ngy SV
screw the 15k service il wait till 20k since my bikes had a easy life...
Old 18-12-12, 12:00 PM   #8
I'd recommend checking them, I've seen them be out on bikes ridden like poofters and seen them all in spec on ones that get zero sympathy.
Old 18-12-12, 12:13 PM   #9
k1ngy SV
does 5k miles really make that much of a big difference? & my bikes fine on fuel and no silly noises coming from engine area... just the exhaust
Old 18-12-12, 12:18 PM   #10
Mark_h
Mark_h's Avatar
So manual makes it all sound dead easy (K3 SV1000) but typically what's going to be seized, jammed, unreachable etc.
Valve clearances suzuki madboy SV Talk, Tuning & Tweaking 4 25-04-11 07:36 PM
Valve Clearances stratman_001 SV Talk, Tuning & Tweaking 2 09-03-10 01:13 PM
Valve Clearances DanAbnormal Bikes - Talk & Issues 31 07-02-08 06:22 PM
Valve Clearances - How 'Ard? Biker_Billy SV Talk, Tuning & Tweaking 19 19-06-07 11:04 AM
Doing the valve clearances... instigator SV Talk, Tuning & Tweaking 7 16-10-06 10:08 PM
