HI,
Could someone tell me what size the middle engine mount bolt is? I know I dont have the right size and will need to borrow tomorrow, its the same bolt the fairing mount / crash bung goes onto. any advice on taking this out with one person or is it a two man job? I just need to remove the fairing fixing kit. |
Be very careful, as they get seized in place.
It it doesn't undo easily, don't be tempted to lean on the socket or spanner with all your weight. Beg, borrow or buy an electric impact wrench. Soak them in Plus Gas over night before attempting removal.
if i understand what your after then it's a suzuki only bolt. the bolt that holds the fairing stays (brackets) is longer than the half/naked bikes so you need to get the shorter ones from suzuki. good news is that dealers usually have loads kicking about due fitting lowers onto S bikes.
Bilbo, I've got to take my shoei to cupar motorcyles tommorrow under warrenty, do you think they will have one?
whats the actual size of the bolt head though.. 22mm it looks like Last edited by JohnStMartin; 14-10-13 at 08:13 PM. |
if its the lower fairing brackets its 17mm if i remember right.
yes Cupar will have them. just ask nicely and you might get for free. you want the main bracket bolts to turn the bike back to an S (half faired) |
brilliant. thanks again.
#7 | |
Amen to that! |
I know from bitter experience
#9 |
Got mine off no bother, thanks for the advice.
Engine mounting bolt size? | Ricky650 | SV Talk, Tuning & Tweaking | 9 | 08-03-12 06:11 PM |
Removing engine bolts. | andrewsmith | SV Talk, Tuning & Tweaking | 8 | 02-01-11 08:56 PM |
Engine mounting bolts help, what am I missing? | bengrrr | SV Talk, Tuning & Tweaking | 9 | 02-09-10 08:22 AM |
Wanted engine mounting bolts for pointy | weecorey | Stuff Wanted | 0 | 17-03-10 03:38 PM |
Where can I buy caliper mounting bolts? | Binky | SV Talk, Tuning & Tweaking | 4 | 07-08-08 10:46 AM |
