Old 14-05-14, 02:46 PM   #1
tfboy
Default water pump cover for 02 curvy
Following the recent high winds and storms, my SV was pushed over and hit a retaining wall which I've just noticed has fractured the water pump cover and it's leaking coolant as soon as I start the bike
Anyone have one going spare? I don't need the water pump, just the cover (and any o-rings and fasteners you might have).
Thanks
Old 14-05-14, 04:04 PM   #2
Nobbylad
Nobbylad's Avatar
Default Re: water pump cover for 02 curvy
Can you use a pointy cover?
If so, http://forums.sv650.org/showthread.p...light=nobbylad
Old 14-05-14, 05:05 PM   #3
tfboy
Don't think so, part numbers are different. Yours has a cable ? mine doesn't.
Old 14-05-14, 05:15 PM   #4
Nobbylad
Nobbylad's Avatar
That's a breather pipe. I thought the pointy covers fitted the curvy models as they work the other way round and I think some curvy owners upgraded to pointy covers after the clutch covers warped.
I'm sure someone else can chip on and correct me if I'm wrong.
Old 14-05-14, 05:31 PM   #5
tfboy
Hmm strange, mine doesn't have a breather pipe. Maybe someone can chip in to confirm either way Thanks
clutch cover and water pump change. SV-Road-Warrior SV Talk, Tuning & Tweaking 5 10-03-14 10:49 AM
Refinishing water pump cover? alol SV Talk, Tuning & Tweaking 3 03-08-12 09:35 AM
Corroding water pump cover. metalhead19 SV Talk, Tuning & Tweaking 8 07-12-10 10:13 PM
Cover for the Water Pump - Curvy Demonz Stuff Wanted 4 15-10-08 07:44 PM
Cracked water pump cover? tradedog SV Talk, Tuning & Tweaking 4 11-04-06 04:09 PM
