Old 04-09-14, 04:03 PM   #1
Bunkle
Bunkle's Avatar
Default Bypassing ignition switch for track bike? Curvy
Hello folks,
I've booked a track day in a couple of weeks time but I've gone and done a blunder and lost my only ignition key
Time is running out to try and find it, I've turned the house over and still nothing. As the bike will only be used on track I was planing on converting the standard loom to a race one over the winter months. Part of that will involve getting rid of the ignition barrel and using the kill switch as the ignition.
Now I'm forced to do that sooner rather than later or my track day's out the window.
I have an '02 curvy SV650.
Can anyone offer any help or advice please? An idiots guide with any photos would be well appreciated as wiring isn't my first language
Cheers,
Dave
Bunkle is offline   Reply With Quote
Old 04-09-14, 04:14 PM   #2
Default Re: Ignition help urgently needed!
I'm no electrical genius. Here's a thread from Svrider.
Ignore my original post, that was for a Pointy, here's Zoran's diagram. If he doesn't know, no one will.
http://www.svrider.com/forum/showthr...=112844&page=2
Old 04-09-14, 07:53 PM   #3
Bunkle
Bunkle's Avatar
Cheers bud, could really do with an idiots guide as in, "take the red wire, cut the blue....."
I've clicked on that link but page one asks for info on an 05 SV.
Thanks anyway fella.
Old 04-09-14, 08:10 PM   #4
Default Re: Bypassing ignition switch for track bike? Curvy
Yes, I'd need a similar guide too
Old 04-09-14, 08:11 PM   #5
Send Svracer a PM
Old 04-09-14, 08:13 PM   #6
Bunkle
Bunkle's Avatar
Will do bud, thanks.
Old 04-09-14, 08:16 PM   #7
Or call out a locksmith & get him to make you a key, they can do this. Might cost.
Or depending on your time frame, buy a 2nd hand lock & key
Old 04-09-14, 08:44 PM   #8
To solve the OP's problem:
Go to ebay, buy a cheapy pattern ignition switch and do the trackday.
There is a simple way to bypass the igntion switch, but for obvious reasons I'm not scribbling it onto a public forum. And it won't be terribly useful anyway, as if you do so even when the kill switch is off to stop the engine, the rest of the bike's electrics will still be on. When you convert your bike to track use the kill switch can be used to switch the whole lot, but it does require some rewiring, not just bypassing the ignition switch.
Although he calls the ignitor a CDI, which it isn't.
Old 04-09-14, 08:51 PM   #9
Bobbydigital36
http://www.ozgoodsautolocksmiths.co....0/info.php?p=3
You send him the ignition and he will cut 2 new keys for £45 posted. Calling someone out is probably going to be around £130+
Old 04-09-14, 08:52 PM   #10
Bunkle
Bunkle's Avatar
Thanks for the advice Sid, I understand why it's best not to explain how to start an SV without a key on an open forum!
If there's anything further you can add to your post could you PM me instead?
Cheers,
Dave
bypassing clutch switch and side stand on 2010 model? cmjhs SV Talk, Tuning & Tweaking 7 19-10-11 09:09 AM
Clutch switch bypassing - the real truth? Reeder SV Talk, Tuning & Tweaking 12 28-07-10 06:33 AM
Bypassing clutch switch permanently. darkdreamsgal SV Talk, Tuning & Tweaking 16 20-06-10 09:41 AM
Pointy ignition switch to curvy? nicky-jano SV Talk, Tuning & Tweaking 2 13-06-09 07:54 PM
Bypassing The Side Stand Switch squirrel_hunter SV Talk, Tuning & Tweaking 10 23-06-07 09:50 PM
