Old 30-01-15, 03:30 PM   #1
timwilky
timwilky's Avatar
Default OMO looking for a suitable remote control light switch
I want to be able to turn on/off the shed lights, particularly the outside one by remote control from the house. So I can see my way there at night.
So I need two channels of remote control both providing two way light switching. Lots of stuff out there seems to be simple on/off. But not switching between between a/b to enable two way circuits.
Anyone got any recommendations. about 20m range required.Obviously in use the receiver is in the shed and the transmitter in the house, so would this require some sort of external receiver at that distance?
Need to support 2 way switching as walking back to the house to use the remote would be a pain.
Not Grumpy, opinionated.
Old 30-01-15, 03:36 PM   #2
ophic
ophic's Avatar
Default Re: OMO looking for a suitable remote control light switch
Does the shed have a separate lighting circuit fed from the house? If it does, you could simply wire in an extra switch inside the house. However I'm sure you would have thought of this.
So what you want is an SPDT remote switch? What if the remote was portable and you just carry it with you?
Silver SV650SK3, Fuel exhaust
Old 30-01-15, 03:41 PM   #3
ophic
ophic's Avatar
http://www.ebay.co.uk/itm/1-Gang-2-W...-/171163594301
popped up in a google search.
Old 30-01-15, 03:53 PM   #4
timwilky
timwilky's Avatar
I suppose I could replace the existing shed switch with something like this But Not confident it would have the range as no direct line of sight etc.
Ideally the receiver should have an aerial that could be external to the shed.
Old 30-01-15, 04:03 PM   #5
timwilky
timwilky's Avatar
The shed power is fed from the garage consumer unit, it has its own 13amp ring and 5amp lighting circuits.
Within the shed, the lighting is currently to a single gange double switch that feeds the internal and external lights. I simply need to be able to turn these on/off from the house. I can see the shed wall from the kitchen. So good line of sight if something could be attached externally
Yes spdt remote switching is required, I could get away with just the outside, but sods law says I will leave on the internal lights and have to go back to turn the damn things off.
Old 30-01-15, 04:33 PM   #6
ophic
ophic's Avatar
Are there appliances in the shed that need to be left on?
Old 30-01-15, 04:43 PM   #7
embee
embee's Avatar
Any use?
http://www.tlc-direct.co.uk/Main_Ind...tch/index.html
Old 30-01-15, 05:02 PM   #8
ophic
ophic's Avatar
Originally Posted by embee View Post
Will keep this system in mind for my shed. When it's built.
Old 30-01-15, 05:28 PM   #9
timwilky
timwilky's Avatar
That looks interesting. I am also now looking towards X10. But seems very expensive to deploy
Old 01-02-15, 06:29 PM   #10
Live in the shed .. . Job done
Poor people to be operated by remote control garynortheast Idle Banter 5 05-01-13 08:18 PM
Recommend me Remote Control software L3nny Idle Banter 9 19-06-12 04:35 PM
using a switch to control headlights. musne SV Talk, Tuning & Tweaking 25 10-02-12 08:44 AM
Remote control cars - Job lot. (pucca racers) Berlin Idle Banter 23 14-11-11 04:04 PM
Does any one here have a remote control model motorcycle ? Shooter Bikes - Talk & Issues 11 13-02-06 08:07 AM
